Pioneer p-6500 AM Problem.
Old Apr 16, 2006
Sinisterdexter's Avatar
I Pinch.
Sinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of light
I just recently re-installed my old Pioneer p-6500 into my vic from my Cavalier. Everything works fine but I get no AM at all. I am curious how AM is transmitted to the radio it self because if I remember correctly it isn't antenna specific.
Old Apr 16, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
am is transmitted through the antenna. did you hook up the power antenna lead?
Old Apr 16, 2006
I Pinch.
As far as I could see every lead is wired to the harness and the antenna is plugged into the radio it self. I can get FM just fine and AM sorta works. I get a very weak staticy signal.
Old Apr 16, 2006
you could try a VW antenna adapter, they have an amplifier built into the adapter. if your going to try that you'll need a reverse vw adapter as well
Old Apr 16, 2006
I Pinch.
I wish I knew why it wasn't working... Before I go out and possibly drop more cash on it.
Old Apr 17, 2006
well the two adapters will only set you back ~20 bucks. every car is different with regards to radio reception when an aftermarket deck is installed.
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Mc7602
Sep 17, 2015 02:01 PM
