where is the 01 sedan headunit install diy
Old Jun 19, 2005
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
my cousin is trying to install a headunit on his 01 sedan. hes having a hard time getting the console out. whats he doing wrong? just pry right?
is there a different proccess for the sedans? i see that sticky DIY up top, but its for the 04-05 coupes.
i dont have much trouble getting mine off, i have a coupe though.
thanks
Old Jun 19, 2005
diskreet's Avatar
its the same thing.
take out the center trim piece that has the cig lighter plug. just pull from the sides to release the clips.
look up through the hole that the trim piece you just removed covered. you will see a metal bar with 2 screws on it. remove them.
go up the the A/C / stereo console piece. pull it out using a flat tip screw driver covered in a towel to prevent damage. there are 9 clips.
install HU.
revearse all steps above except installing HU. leave that in!
OH so you know: Te first time taking the console piece out with the HU and HVAC controlls it was VERY hard in my 01 sedan. VERY hard to get out! Took alot of prying!
Old Jun 19, 2005
SOHC's Avatar
thanks, yeah he just discovered the 2 screws. guess thats the only dif vs coupes.
Old Jun 19, 2005
Rennen's Avatar
New Mod on the Block
umm... dont coupes and sedans have 2 screws holding in the console?
Old Jun 19, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
i dunno about sedans but coupes do, it looks like u have a sedan, does urs?
Old Jun 19, 2005
Rennen's Avatar
yeah, it does. so i guess bith have em...
Old Jun 19, 2005
diskreet's Avatar
no all of them should have the screws.
anyway welcome!
Old Jun 19, 2005
Karumba's Avatar
Boredom causes changes ;)
thanks
Umm to my knowledge 01 sedan and coupe are the same..
just you looked at the wrong DIY .. - http://www.7thgencivic.com/forums/sh...d.php?t=153830 (found through DIY area under Audio)
Old Jun 19, 2005
MegaHurtz's Avatar
search, it's out there
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Ilikemscruffy
Jun 26, 2015 09:51 AM
Youshoe
May 22, 2015 09:36 PM
ROBREALZCIVIC
Nov 16, 2001 06:53 PM
