what speakers?
Old Nov 24, 2004
civicdude04's Avatar
civicdude04 is an unknown quantity at this point
what speakers?
what would be a good set of 6.5" components(front) and 6x9's(back) to use for listening to techno, and rap? i want something with some good mids, and highs. i dont really care about lows, since i have a kappa perfect 12.1d sub for that. dont want to spend more than 200 on a pair. will be running them off of my alpine 9835 for the time being until i get an amp. please help me out! thanks in advance!
Old Nov 24, 2004
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
alpine type s 6x9's and type s componants in the front
Old Nov 24, 2004
Kenny's Avatar
Kenny is an unknown quantity at this point
for me...I don't care the 6x9(back) and I will put the alpine SPX-177R on front..
Old Nov 24, 2004
brash's Avatar
brash is an unknown quantity at this point
I'd recommend buying an amp instead of rear speakers.
For front speakers, any of the following would probably sound good:
JL Audio VR or XR
Adire Koda
CDT CL-61a
Polk MOMO
It's worth looking into the mid-to-high end stuff made by Alpine, Boston Acoustics, A/D/S, and Infinity. And I'm sure someone else can recommend speakers, too.
There is no "best" speaker. You'll be happy with quite a number of different speakers.
Old Nov 24, 2004
I like my infinity reference. I'm running them amped with no sub and they still give a good thump on some songs. But you might want to look at something higher end. Just be sure to get am amp for them.
Old Nov 24, 2004
dont the alpine components rms pretty low tho? i was looking into the infinity kappa components for the front and the kappa 6x9's for the back, but i heard they have good highs, but weak mids. is that true?
Old Nov 25, 2004
thom's Avatar
/////ALPINE
well alpine stats that the type s components dont need an amp.
Old Nov 25, 2004
That's what I've heard about the infinity. I do have separate tweets installed and they sound great. I don't know why everyone says mids suck. On certain songs, I can get some good bass out of em. They sound great. Maybe they mean the quality isn't as good as other speakers.
Old Nov 25, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
get mb quarts or focal. and you will cream ur panties. but they are pricey and require amps to run.
even im looking for some front speakers that will go well with my alpine deck and rear 6.5 infinity kappas.
Old Nov 25, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
I second no rears and amp the fronts. Why so many people don't amp their fronts boggles my mind. IMO, its what makes or breaks a system.
Old Nov 25, 2004
I have rears with dymanat in the deck and it sounds decent with a +2 front fade. You don't want any rear fill up front, but without speakers you'll have people asking you why they can't hear anything back there
Old Nov 25, 2004
Kenny's Avatar
usually if you watch DVD in the car, you need the rear speaker, because you can get the surround sound, you can't hear the music from rear if you add the sub in the trunk..so I just put a good amp and front speaker and cut the rear speaker and add a mono amp and sub
Old Nov 25, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
For fronts, I'd say a pair of Adire Koda mids or the Kickers that (I think it was fonto) that has them. I can't think of the model number right now, but we used them in a guys truck last week and they were good with the lower frequencies. For the component tweets, I'd say either image dynamics or planet audio tweets, or something along those lines that will give you highs at a decent price (you can pick them up fairly cheap off of ebay). The reason I don't like Infinity's, especially for someone whom listens to rap and techno, where there's boomy mid and low frequencies is because they are somewhat harsh, and can't get s low and fill the gap between highs and lows as well as some others. I wouldn't go with rear fill unless you just insist on something blaring in your passenger's ears. If I were doing anything for rear fill, I'd leave the stocks in there ran off of the deck. I'd like to fit a single 8 up there to fill between the mids and sub, (mainly an idea I had for my setup or put one somewhere in the center rear floorboard, just to give me the higher portion of the low frequencies, and get the other, more punchy frequencies that my other sub doesn't cover as well.)
Old Nov 25, 2004
Slawek's Avatar
Proudly Canadian
Slawek is an unknown quantity at this point
get some boston acoustics
Old Nov 27, 2004
just ordered kappa components for front, gonna amp them, and kappa 6x9's for the back, amping them as well
Old Nov 27, 2004
thom's Avatar
/////ALPINE
i'd say...
go to the audio store and see for yourself
Old Nov 27, 2004
4Saris's Avatar
4Saris is an unknown quantity at this point
I third that. I've had 6x9's in the coupe, and they were overpowering the front. The OEM's were sufficient and amping the fronts did more good for the SQ.
Old Nov 27, 2004
The rear is tricky due to the glass being so close. It makes for some interesting sound (bad). Fade to the front a bit until you can barely hear the rears if at all.
Another thing. Dynamat will help the mids alot in the front doors. I was amazed what a difference it made even with infinity reference. What amp do you plan to use for the components?
Old Nov 27, 2004
4Saris's Avatar
Besides, the biggest pain in the *** with installing anything in the Civic Coupe is removing the rear panel. I still say you don't change the OEM's.
Old Nov 27, 2004
fonto's Avatar
The LA Clipper
I have Kicker RMB midbasses in the doors, and Phoenix Gold Ti Elite Components
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
