Somthin strange happening with my system help!
Old Feb 21, 2004
joedc5's Avatar
joedc5 is an unknown quantity at this point
Hi all, My car is in the body shop and is almost done. Before it went in I notice something strange every time I turned my system up volume at 25 or up it will play shut off for a little and then play again and will keep happening if I don't turn it under 25. I am like what the F*** is goin on??? Does anyone know? I am runnin a Kenwood touch screen ( forgot the mode) with 2 alpine type-R 10s Type-R components and a V12 alpine amp ( the smaller one).
Thanks for all help! Joe
Old Feb 23, 2004
WhiteRabbit's Avatar
amp is going into protect.
if it happens afer play for a little while, its probbaly overheat protection.
if it happens with teh amp cold, its probbaly overcurrent protection, or clipping protection.
in the case of overheat, retuning or active cooling can help.
in the case of overcurrent or clipping, retuning or new equipment is a must for prevention
good luck
Old Feb 23, 2004
joedc5's Avatar
The funny thing is I had my amp disconnected along with my subs because I am doing work in the trunk. The wires are touching and I wrapped each one with electrical tape. Could this be my problem?
Old Feb 23, 2004
blouisgod's Avatar
Life Begins > 6800rpms
Most likely crossed wires. This happened when I reinstalled my amp and subs. When the bass would hit, the vibration would cause wires to cross and cut out the system.
Old Feb 23, 2004
joedc5's Avatar
Hmm. thats strange, But i understand it's a safety thing. I will be rewiring since I am rebuildin the trunk. I just ordered the ALpine M500 for my Type-R Subs!
lilrob1213
37
Jun 29, 2015 06:45 PM
RIPSAW
Jun 9, 2015 08:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
SpdRcrChk
Jan 3, 2002 07:11 PM
supercivic01
South
Nov 30, 2001 11:27 AM
