Want New System!!!
Old Feb 16, 2004
2003CiviC's Avatar
2003CiviC is an unknown quantity at this point
Want New System!!!
i have an Alpine 9813 Head Unit with an Alpine MRD-M500 and MRV-F540 and I dont know what kind of subs to get. I had two Rockford HX2's but then there werent hitting very hard. I dont know if I should sell these amps and get a whole new system or keep them and work from there. Also has anyone else had any experience with the M-500? When I turn the bass up too loud it would shut down on me. Any input would be apreciated. Thanks.
Old Feb 16, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
I have a M350 in my truck. I haven't had any trouble.
Old Feb 16, 2004
doubledeuce2k2's Avatar
sounds more like installation than equipment
Old Feb 16, 2004
WhiteRabbit's Avatar
if youd like to meet up, come down to fresno on the 22nd of februare. theres gonna be a dB drag event, if youd like to get metered, or jsut get advice from Scott Stoner, who has held a state record for a short time and the leading spl competitor in his class in central california, its a blast to go!
definitely the best spl competitions ive ever been to are held in fresno... Ill be there myself sporting three w6's seeing if i cant actually meter high for once...
Old Feb 17, 2004
2003CiviC's Avatar
The amp doesnt turn off. It says error so I am sure that it has nothing to do with the installation. I am running 4 gauge wires and have monster RCA cables. I have also tried another amp in my car and blast it with out any problems.
And if i can i will try to come out to the meet on February. N e one got n e inputs on what subs I should get???
Old Feb 17, 2004
im curious, is the M500 a 500 watt alpine? and is it 2 ohm stable?
my first thoughts are:
the alpine is 4 ohm stable only and the HX2's (assuming power) are wired for a 2 ohm load, causing the amp to go into protect.
as to it not being loud, if the M500 is rated for 500 rms at 2 ohms or 4 ohms, they are HX2's! power hogs, they need power to get loud!
Old Feb 17, 2004
my first thought on what to replace it with would be "something more efficient"
like an IDmax, or a tempest, or a pair of w3v2's, or a w6v1
Old Feb 17, 2004
civicmorph's Avatar
civicmorph is an unknown quantity at this point
yea ^^^ definitely agree if that's the case, HX2s have some power, I mean some power if hooked to a powerful amp...if ur RMS is 500 watts from your amp you definitely need better higher powered amps. My 1 HE2 10inch RF is hooked up to a 460watt RMS Kenwood amp and pounds like no other...(and that's only at half the sub level I set at).
Old Feb 18, 2004
2003CiviC's Avatar
Thanks for the input. Where is the cheapest place that I can find those subs? And i never heard of IDMAX before. Are those n e good?
On the birth certificate fro my amp it was rated at 512.3 watts RMS. So its pretty powerful but then it didnt knock my subs that hard. Cuz when i hooked it up to the old V12 series it hit hella hard.
Old Feb 18, 2004
civicmorph's Avatar
that's 512watts RMS to two channels I assume? then u'll have half that for each of ur HX2 subs...and HX2 subs have at least 500rms each, 1000max at least...so yea u'll need much better amps...btw, ur enclosure is very important especially for RF subs, since they require a lot of space.
Old Feb 18, 2004
Regularjoe's Avatar
Its a monoblock.
500 rms @ 2 ohms
250 rms @ 4 ohms
Hopefully they are DVC 2 ohm, so best case each sub gets 250 rms, 500 max. If he wired it wrong, or they are DVC 4 ohm, he probably is getting 125 rms, 250 max each. Either way they can take way more power.
Old Feb 18, 2004
i love mine . gets loud on very little power. gets very loud with lots of power.
Old Feb 18, 2004
IDmax was an sql woofer before the coining of the term "sql". its one of the first super woofers, and today remains a very popular SQ competition subwoofer while others like hte audiomobile MASS have died out.
Old Feb 18, 2004
2003CiviC's Avatar
The HX2's were wired to 2 ohms. I had one of my friends who worked for a shop check the ohm rating on the subs and it came out to jsut a bit over 2.xx. So I am thinking that it is the amp. I think i might have to check out these IDmax subs. Thanks for the input guys.
Old Feb 18, 2004
www.imagedynamicsusa.com
ebay isn't much cheaper than where i got mine www.audionmore.com unless you pick up a used one.
Old Feb 18, 2004
civicmorph's Avatar
My HE2 RF sub is DVC 4 ohms, so his HX2 is of course DVC 4 ohms cause his sub is a higher model then mine, much higher
Old Feb 19, 2004
2003CiviC's Avatar
My rockfords come in two different sets though. U can get the DVC 4 ohms or u can get the DVC 2 ohms. They make them both for the rockfords HX2's.
Which head unit do you guys think is better, the Alpine 9813 or Pioneer DEH 8500???
coumadin01
Electronics
25
Jul 25, 2019 04:19 PM
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
