4-12 L7s Fiberglassed!!! PG. 2 PIX
Old Feb 15, 2004
  #31
michael_on_18s's Avatar
michael_on_18s is an unknown quantity at this point
used 3/4 mdf for the base, the sides, & top have been molded with layers of fiberglass. Laid fleece over the braces the fiberglassed to get the molded look, used a powersander for the flat surfaces (which are few), but had to hand sand in the edges, and top part. A power sander if not used carefully will deffinetly ruin your box. If i had a better camera I would take Up close pictures, but i assure you there are no craters or divets in this box. I maid sure of it, Apprx. time it took me was close to 3 mo's, but the end result was way worth it.
Old Feb 15, 2004
  #32
WhiteRabbit's Avatar
did you load the glass in the inside or the outside of the fleece?
Old Feb 15, 2004
  #33
outside.
Old Feb 15, 2004
  #34
pnoyster2k1cvic's Avatar
Balut Eating Champ
this thread is killing me... so where's the picture?
Old Feb 15, 2004
  #35
civic01vtec's Avatar
they are on pg 2......u don't see them?
Old Feb 15, 2004
  #36
page two (2)
Old Feb 16, 2004
  #37
did you use even layers of weave, or matting cut into squares?
General DIY
Sep 25, 2015 08:02 PM
KronikScott
Jun 9, 2015 08:00 PM
Jigee
May 9, 2015 11:18 AM
NeonNights
Mar 4, 2002 06:50 PM
