Fosgate 301X????
Old Feb 12, 2004
chicohonda02's Avatar
Since 2002 Baby!
Fosgate 301X????
Any of you have experience or knowledge of this amp? Do ya think it would be decent to power the fronts and rear? Its not all that much power, but everyone says you can't always go by the specs.
Specifications
* 40 watts RMS x 4 at 4 ohms
* 75 watts RMS x 4 at 2 ohms
* 150 watts RMS x 2 bridged output at 4 ohms
* 2-, 3-, or 4-channel output
* 4-ohm stable in bridged mode
* Tri-Way capable
* requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
* front and rear switchable high-pass (120 Hz, 12 dB/octave) and low-pass (80 Hz, 12 dB/octave) crossovers
* MOSFET power supply and output devices
* Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
* TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
* Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
* NOMAD — advanced protection circuitry for "intelligent" shutdown protection
* speaker- and preamp-level inputs
* preamp outputs
* 12-1/16"W x 2-3/8"H x
Old Feb 12, 2004
Since 2002 Baby!
here's a pic
Old Feb 12, 2004
doubledeuce2k2's Avatar
depends on the speakers. for 2 or 3 way coaxial speakers, it'll be plenty
for some components, it'll be fine
for others might be a little light on power
Old Feb 13, 2004
alex053's Avatar
its a good amp that will put out more than the 40 watts that its spec'd at. you wont get overwhelming output but you will be able to listen to your radio with the windows down finally. good amp for the money
Old Feb 13, 2004
Since 2002 Baby!
They'd be going to the front Bostons FX series and Eclipse 6x9's.
Cool Thanks fellas.
Old Feb 13, 2004
mrjdavidson's Avatar
mrjdavidson is an unknown quantity at this point
Good amp powers my front and rear pioneer component 6 1/2s
Old Feb 18, 2004
BRCivic's Avatar
BRCivic is an unknown quantity at this point
Yeah, it should be fine for you. I have my 801x powering just my front speakers (Pioneer TS-A1670R's) for now (rear FRC4269's are coming within in a week...) and I have the gain all the way down - literally, all the way down - and it's still loud as hell. And remember, this is with only the two front speakers powered. The rears(stock for now) are still being pushed off the HU, and they're barely audible.
BTW, the 801x pushes 100w x 4 RMS, so 40w RMS x4 should be more than ample.
Old Feb 19, 2004
Since 2002 Baby!
Cool Thanks, your input has helped. I appreciate it.
Late
redcloud
25
Aug 12, 2015 01:23 PM
noahnoah
Feb 12, 2003 12:40 AM
BlueStepSide
29
Jan 8, 2003 07:21 PM
hobbes
Oct 29, 2002 06:21 PM
hobbes
Oct 26, 2002 10:41 PM
