Engine Swaps Post information/questions about Engine Swaps here.
R18 transmission swap to manual
Old 02-21-2017
R18mugen's Avatar
R18mugen is an unknown quantity at this point
An associate of mine said it would not be worth it to swap the transmission on my r18 I have to ask why not the manual transmission is cheaper and more fun to drive so what would be a set back if i change my automatic transmission if it breaks
Old 02-21-2017
Re: R18 transmission swap to manual
Sell the car you don't want, use that money to buy the car you DO want?
Old 02-21-2017
R18mugen's Avatar
the question is if the transmission goes bad would it be better just to switch it to a manual
Old 02-21-2017
The legs in the public bathroom stall
mcnoople's Avatar
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Do you have all the parts required. You would need an entire manual trans car to get all the brackets, clips, linkages NOT just a trans. You would also need a pcm for a manual car which would need programmed to be able to start the car. Starter may be different. The axle almost certainly are.
I have considered swapping a manual trans into my accord. It is a lot of work even for me and I am honda dealer tech and have a complete donor car to get all the parts from.
Old 02-21-2017
R18mugen's Avatar
So I'm better off saving for an si thank you
Old 02-21-2017
If you're looking to build 200+ HP, then yes an SI would be a better base to start with and the SI only comes with manual trans.
Drive the R18 as an econobox, brag and boast about killer gas mileage LOL
