Kaminari KTR II Carbon Fiber wing
I just wanted to know what everyone thought about the wing. I have it and its being painted white and will have the carbon fiber blade. Let me know your opinions on it.
Kaminari KTR II wing Pics (part 1)
Kaminari Wing (part II)
I have it on my sedan and it is a perfect fit.
With my lowering I had to increase my displacement in the rear about 1/2 inch higher to accomidate for the down pressure during acceleration.
They sit further under the edge with a slight angle down. You probably won't notice a v-cut out unless you have a light colored car or neons
Samari, it will fit perfectly.
The only trouble I had was with drilling the holes, one lined up with the trunk support frame. Had to drill it out. But I also have a sedan, it may be different with the coupe. Good Luck
thanks for the tip. I think it will go it perfectly with the stock oem holes. From what i heard, that holds true. i just going to use the oem spoiler install directions.
I got the wing out the paint shop today. I will be installing it soon. Here is a pic of it if you would like to see what it looks like with white post was carbon fiber blade.
http://www.7thgencivic.com/memberrid...php?photo=6565
Okay, i got the spoiler intalled and I love it. Check out my ride. The install was a sinch. Just use the OEM spoiler install directions basically except for the hole for the wires on the led brake light cuz it doesnt have one. Drill through the oem holes and put the spoiler on. Easy as that. If you need help feel free to email me and I will do so.
Bruce2
Sep 27, 2015 08:45 PM
fecrni
Aug 8, 2015 06:15 PM
Reppin Stage 7
