Sponsored by:
Sponsored by: CARiD
rattling with your hks hi-power muffler?
Old Apr 3, 2003
vino's Avatar
vino is an unknown quantity at this point
does anyone have a rattling noise with their hks muffler???....i have a rattle from one of the hangers...the one on the right side of the car.....its hitting another piece of metal.....any1 have this problem also?? what should i do? its really annoying!!
Old Apr 4, 2003
Panda
Guest
Posts: n/a
i had that problem also, its easily solved by going to pep boys and getting another donut ruber hanger, place it in between the piece that is rubbing and the old hanger, then use duct tape to secure it . not a big problem
Old Apr 4, 2003
nightkids1's Avatar
Initial D!!!!
mine did the noise also, it just stoped atfer a month.
Old Apr 4, 2003
Spazbitte's Avatar
Spazbitte is an unknown quantity at this point
Duct tape nice! You can also see if its to tight to the bumper or just incorrect installation. Just rebend the pipe so it fits. Loosen it up and wiggle it around if you got the tools.
Old Apr 4, 2003
Jmoney's Avatar
Jmoney is an unknown quantity at this point
I've got the same problem myself, waiting for some nicer weather to go out and fix it.
I'll have to try that Panda
Old Apr 4, 2003
vino's Avatar
ill have to try that myself panda....thanks to everyone that replied
Old Apr 5, 2003
Mbow's Avatar
It's probably hitting the rear sway bar due to vibration. I would try to find a thick peice of rubber to place on the contact point. You should be able to figure out where the contact is being made. It will leave a visible mark on the area.
Remember that whatever is placed in the area is going to encounter extreme heat.
Old Apr 5, 2003
ChEe12iO's Avatar
ChEe12iO is an unknown quantity at this point
you could use exhaust wrap around the section of exhaust that's contacting the rear sway bar. that should do it. i have the same problem. when the weather breaks here i'm going to do the same thing.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
rovafa2002
Sep 28, 2015 06:57 PM
yyyktk1
Sep 12, 2015 04:02 PM
fvckbg
Sep 8, 2015 09:55 PM
