Sponsored by:
Sponsored by: CARiD
removing dash for painting help!!!
Old Sep 11, 2002
1hot01civic's Avatar
1hot01civic is an unknown quantity at this point
I was wanting to paint the dash on my car, not actually the whole dash, but if you follow the top of the door line and follow it to the dash that is the part I was wanting to paint. It looks as if that part is seperate from the top of the dash. I was wondering if anyone has had that part out, and if so how hard was it to do and put back in?[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Sep 11, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
DIY to take out door panels
It is VERY easy.
Old Sep 11, 2002
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
Tech stuff?!?!?!?!?!
Old Sep 11, 2002
Sorry i posted in the wrong area, but the doors I am not worried about it is the molding line on top of the door that follows into the dash. I was talking about the dash (the area that runs above of the glove box around the radio and runs around the gauge area and meets to the other top of the door molding line)again sorry for my post in the wrong area. I searched in both but couldn't find in either one so I posted it here
Old Sep 11, 2002
sumama's Avatar
sumama is an unknown quantity at this point
nice diy, but doesnt seem too simple to me.
Old Sep 11, 2002
I wasn't talking about vent and door handles I am talking about the dash
Old Sep 12, 2002
Bartkat's Avatar
These Pieces?
Item 6?
Old Sep 12, 2002
Connie's Avatar
You mean item 5 buddy, not item 6
Old Sep 12, 2002
yes item #5, has anyone taken that piece out
Old Sep 12, 2002
Bartkat's Avatar
Quote
[hr]Originally posted by: Connie
You mean item 5 buddy, not item 6[hr]
Right, item 5. So far nobody else has made clear which part, so I posted the drawing.
Old Sep 12, 2002
thanks for the drawing, hopefully someone will understand what part I was talking about
Old Sep 12, 2002
Bartkat's Avatar
I would suggest that if you can't take the exploded view and figure out how to take it apart, that maybe you shouldn't be trying to do such things. Also you need to be concerned about working around that passenger side airbag.
There is another thread here where a guy mangled his dash trying to pry off parts with a screw driver. Others have ruined their gauge surround trying to install indiglo, etc. Once something like that is messed up, it's hard to fix or you have to pay the cost of replacement parts.
Just a word to the wise.
I think there are some precut, dash covers available, but I don't remember where.
Old Sep 12, 2002
I have ordered indiglo gauges and plan on DIY install, from drawing it looks like clips holding it in and 2 screws, maybe when I put my gauges in I'll get a better look at it
Old Sep 12, 2002
Bartkat's Avatar
Here's a DIY that shows how to do the center dash trim pieces. I think that has to come off too before the dash pad comes off.
PAINTING TRIM PIECES
Old Sep 12, 2002
Bartkat's Avatar
GAUGE FACES DIY
The trick for removing the gauge pod is to lift it with a thin wide blade, using the shaft of a screwdriver as a fulcrum. That way you aren't prying against the trim. That is, of course after removing the screws. Once you have that pod out, and unplugged, you can take the whole pod in the house and work on it under better conditions than in the garage. If you want to put custom trim around the gauges, this is the time to do that too, so you don't have to pull the gauge pod out twice.
Old Sep 12, 2002
Bartkat's Avatar
THE ENTIRE DIY LIST
Old Sep 13, 2002
I am still thinking about it,but thanks for the concern. It is something I really want to do though, maybe start my own DIY. Think it would look real sweet!!!
Old Sep 13, 2002
importz2k1's Avatar
I did my entire dash. The trim pieces have to come out first (radio, panel under it, vents etc....)
Before you try to take the air bag out, disconnect the battery, and to do the part that you want, you will have to take out the entire dash so you can get to the screws that hold it in!
Good luck!!! Took me 15 hrs for the whole process (removal, painting, putting back together)
Lots of screws!
Old Sep 13, 2002
where to begin?
Old Sep 19, 2002
Incapearl01's Avatar
Incapearl01 is an unknown quantity at this point
unless you waqnt to pay the dealership $300 then you will need 8! hours of free time. I've done it and you need special tools also, because there are several bolts that are tucked under and around the air bag.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
usajags84
15
Aug 19, 2015 03:12 AM
OneJzSupra
Jul 9, 2015 06:40 AM
brags
Jun 16, 2015 01:18 PM
KronikScott
Jun 9, 2015 08:00 PM
