Question about starter that's going bad
Rep Power: 0 Question about starter that's going bad
Hey guys.
The other day my 2007 civic had a very hard start when trying to start with a hot engine (ran a quick errand and tried to start the car about 5 minutes after shutting it off)
It was a slow, hard start. It took two or three tries.
I've noticed some other slightly hard starts before this but nothing really serious.
I took it into my shop and they said it was the starter.
I have had no problems starting it in the past few days since I brought it in. Starts right up no matter what.
If it is the starter, realistically, how long can I put this off? Will it just not start one day or will I have some signs that I need to take it in ASAP?
I just can't spend over $600 on this right now.
Thanks!
Thanks!
Re: Question about starter that's going bad
If the starter is intermittent it's on it's way out and no one can tell you how long it will remain intermittent before it finally stops working. If it does fail in the meantime you can try tapping on it with a tire iron (in trunk). If you can change it out yourself a used OEM starter should be less than $75 junkyards. Aftermarket new or remanufactured $150 or less. You may even find a shop in your area that rebuilds starters.
Rep Power: 0 Re: Question about starter that's going bad
Do you have towing through your auto insurance or AAA? if not can you afford a towing bill if you are stranded due to a no-start situation?
I do have 100 miles of towing through AAA
If it has only started hard once in the past week does that mean I have more time? I'm not familiar with starters. Do they just die with no warning or will I have more hard starts before it actually goes?
It will continue to not work intermittently, until it doesn't work at all.
Replace it now before it leaves you stranded at the worst possible time and place.
You can't reach the starter from above, you would need to be under the car.
It just seems odd since it only hard started once and I have had no other issues since.
Does someone have a diagram of where the starter is underneath in case I need to tap it?
Thanks
1.8L engine: It's under the intake manifold on the back of the block.
