i want my car lower
Rep Power: 0 i want my car lower
well, right now i'm sporting neuspeed race springs on my civic with stock shocks. it's supposed to drop the car more than 2 inches. with my 17 inch rims and 2054017 tires, my car still seems a little high. i wanted to know if anyone can recommend something to make my car a little lower. and no coilovers please. i hate coilovers. possibly some adjustable shocks? please help. thanks!
Rep Power: 0 Shocks are only adjustable for bound and rebound, not for height (to the best of my knowledge). That means your options are either springs with adjustable perches (called coil-overs here), or a FULL coil-over kit: Shocks with threaded bodies which allow for spring adjustment, hence, ride height adjustment. Koni, Eibach, Tein, and H&R are some of the best...read somewhere that Tein is coming out with an electronically-controlled coil-over kit, adjustable from the cockpit...you'll have to search for that...lazyness is setting in.
Hope that helps
Hope that helps
Rep Power: 0 << read somewhere that Tein is coming out with an electronically-controlled coil-over kit, adjustable from the cockpit... >>
The are called the Tein Type Flex they run around like 3g's and they are not height controlable from the cockpit. From what I have heard they control panel controls the damper, rebound and camber (or something to that effect) from inside. They are some bad a$$ coilovers in general Tein makes great equipment.
The Standard One
Rep Power: 392 if you go any lower your going to need new shocks soon so i would recommend a full coilover kit. because springs + koni's = about 700. pay that lil more and get true coilovers... heard the ride were nice on those... if you do decide to only go with springs i think only one or two companies make them that low. forgot which one tho.
mistermenphis22
04-03-2016 08:06 AM
