Question on putting on a sunroof on a lx
1 Post
Rep Power: 234 Question on putting on a sunroof on a lx
well i have a 2002 civic sedan lx and i want to instal a sunroof.. the question is i found a sunroof at the junk yard and i want to know is there a different between a coupe and a sedan sunroof? is it the same ? does the lx roof has holes to screw in the sunroof or do i have to modify it by cutting the hole for the sunroof and then straight weld it on?
New Mod on the Block
Rep Power: 297 Re: Question on putting on a sunroof on a lx
you probably shouldn't try to do this yourself. unless i'm mistaken, the LX didnt come with a sunroof, so you're obviously are going to have to cut into the roof of your car and everything would have to line up perfectly. then you'd have to create mounting points to hold up the setup. then you're going to have to wire it and have a custom headline made. seems like a lot of hassle to have a little sun come through the roof.
A moonroof is awesome, i use it all the time if i have the chance. I would get a quote from a couple of shops to get it professionally done. You dont want it to leak or anything.
1 Post
Rep Power: 234 Re: Question on putting on a sunroof on a lx
well i just wanted to know if the moonroof from the coupe and sedan are the same. cutting and welding is not the problem to me. if it doesnt turn out the way i want then im just gona cut the hole and rubberseal it wit just the glass peice only. i dont mind having a unopen sunroof lol. i just want a open roof..if u guys have any suggestion on how to then it would be very helpful.
Wild Cranker
427
01-28-2016 06:49 PM
ashlava71
05-16-2015 12:54 PM
