Lightened Underdrive Pulleys......Its ok to change the Crank!!! - Honda Civic Forum
Sponsored by:
Sponsored by:
Old 03-09-2002
01Ex is an unknown quantity at this point
3) "Isn't my stock crank/eccentric pulley a balancer, harmonic/torsional, or vibrational damper?"
A common misconception is that factory crank pulleys on certain vehicles are harmonic dampers. The fact is, on todays late model cars the factory crank pulley is designed to reduce NVH (noise / vibration / harshness), which does not affect crankshaft or bearing life. These are noises and vibrations from the engine compartment that may travel into the cabin of the vehicle when the engine is running and the stock crank pulley is used to reduce NVH for the occupants (similar to the use of resonators in the intake to quiet intake noise). We do not manufacture crank pulleys that replace or eliminate a damper in applications where the factory crank pulley is an actual harmonic damper (such as 90 degree V engines).
I pulled this off of http://www.unorthodoxracing.com/faq_pulleys.html.
01Ex is offline
Old 03-09-2002
DIY King
Grey's Avatar
Hum... I guess. Kind of calmes me down and makes me want to buy a set now.
Grey is offline
Old 03-09-2002
VTECnique's Avatar
VTECnique is an unknown quantity at this point
do not change the crank pulley! you will blow your oil pump out! a few guys at my local tuning shop said that the crank pulley should only be used for hardcore racing, because of that fact.
VTECnique is offline
Old 03-09-2002
01IncaPearl is an unknown quantity at this point
I changed the crank pulley on my Accord and drove it hard for almost 3 years and never had any problems with it ruining anything.
01IncaPearl is offline
Old 03-09-2002
Bartkat's Avatar
<< do not change the crank pulley! you will blow your oil pump out! a few guys at my local tuning shop said that the crank pulley should only be used for hardcore racing, because of that fact. >>
What is the process by which a lightened crank pully destroys your oil pump?
Bartkat is offline
Old 03-09-2002
Mbow's Avatar
We need some good reliable information about the effects of switching out the pullies. Seems there is no concensus around the subject. I am interested also.
Mbow is offline
Old 03-09-2002
black2k1vtec is an unknown quantity at this point
You just have to match it up with a lightened flywheel!!
The theory is that a crank pulley disrupts the balance of the crank, therefor wearing the bearings and causing harmonics and unwanted vibrations that are hard on the bottom end.
Im gonna leave mine stock.
black2k1vtec is offline
Old 03-10-2002
mohawkboom's Avatar
Think about this for a minute okay.. The Crank pulley is always under tension and being pulled in one direction from the Belt. see..therefore any weight or "balancing" it may have doesn't affect diddly squat as the tension on the crank pulley varies.. Turn the steering wheel.. the power steering pumps adds pressure, therefore pulling on the crank more.. he he pulling crank [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]..Turn on the A/C and deffoggers, crank your system.. takes more power to turn the alternator.. more tension throwing the pulley further off balance..oh my[IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG]....
in 90 Degree v-block engines this comes into effect more because tension is equal accross the crank pulley from the Timing gears and belt tensioners...
Hmmm I know it I Rule![IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG]
Cheers
Mohawk
P.S. If you want a sound syste.. DO NOT EVER GET UNDERDRIVE PULLEYS!
mohawkboom is offline
Old 03-10-2002
VTECnique's Avatar
thx 4 explaining that 4 me Black2k1vtec
Old 04-02-2002
ZZCIVIC is an unknown quantity at this point
If all this worrying is keeping you awake, then I would say DONT get em....HOWEVER, so far, in 5 years of use, UR has not had ONE engine failure......If a light pulley is bad, then a HEAVY one should be great....if you want to go by that reasoning. I wonder why race engines have such light pullies???? Hmmmm....
ZZCIVIC is offline
Wild Cranker
427
01-28-2016 07:49 PM
McLean
06-13-2015 11:32 AM
MN-02-CivicEx
28
05-02-2015 10:11 PM
Trav_02civic
Engine start problems
04-23-2015 09:57 AM
Quick Reply: Lightened Underdrive Pulleys......Its ok to change the Crank!!!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
