Are the camber kits easy to install yourself?
Rep Power: 0 Are the camber kits easy to install yourself?
Are they. I know the front camber is just a bolt so that's easy but what about the rear? I know it is a whole new control arm but is that hard to install. I have air tools if that helps and my dad knows quite a bit about cars and how to fix them.
DIY King
Rep Power: 394 Did you see the DIY's? If not, then check them out. I don't think it'll be that hard. Go to the Tech Stuff forum and look in the Mega DIY thread.
Rep Power: 0 JUST AS LONG AS YOU HAVE AIR TOOLS AND SOME HELP, YOU'LL BE FINE. THE FRONT IS EASIER THAN THE REAR. GOOD LUCK INTALLIN EM. IT WONT BE TOO HARD!
Rep Power: 0 << Are they. I know the front camber is just a bolt so that's easy but what about the rear? I know it is a whole new control arm but is that hard to install. I have air tools if that helps and my dad knows quite a bit about cars and how to fix them. >>
Yo you wont have to worry about your tires.
