LOWERING A SEDAN - Honda Civic Forum
Sponsored by:
Sponsored by:
LOWERING A SEDAN
Old 02-04-2002
phlipsidez is an unknown quantity at this point
LOWERING A SEDAN
I am thinking about lowering my sedan. I am probably going use Sprint springs (2" drop). I've done searches on this, but I want CONCRETE, EXPERIENCED answers: 1) will i need a camber kit? 2) will i need new shocks?
phlipsidez is offline
Old 02-04-2002
pounds's Avatar
pounds is an unknown quantity at this point
with a 2 inch drop...you will need both.
if you dont get the camber your alingnment will be off....and if you dont get the shocks then you better drive careful, cause you can bottom out your shocks and possibly blow em out.
i would reccomend both
pounds is offline
Old 02-04-2002
mohawkboom's Avatar
Okay... Answer is.
Suspension is the same as the coupe. With the exception of wheel clearance in the well. Otherwise everythings the same. Fo what's good for coupes is good for sedans..
BTW. I drive a sedan as well.
Cheers
Mohawk
mohawkboom is offline
Old 02-04-2002
netcbc is an unknown quantity at this point
for a sedan, i think its best you go with neuspeed, h&r or eibach, buts it up to you, even with these high quality springs, ppl with sedans have busted there shocks in 1 year......... if your really worried about busting yoru shocks, get ground controls
netcbc is offline
Old 02-04-2002
AJ
AJ is an unknown quantity at this point
I have a sedan and I went with Sportlines 1.75" because I wanted a great ride. I hate the bumpy rides. I looks great I don't have any pic's up yet soon though. I have to get a camber kit for the rear cause it tilts in. But if you want a great ride go with sportlines.
AJ is offline
Old 02-04-2002
OK, this is gonna be a dumb question: if i get coilovers, it will replace not only my springs, but also my shocks as well, so i won't need to buy anything else (except a camber kit), right?
Old 02-04-2002
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
You will def need a camber kit.. i have the pro kit and i could use it.. and 2"? then i would start saving now for new shocks..
Mine
DogstyleEX is offline
Old 02-05-2002
hey dogstyle, i looked at your pics and i like the way it looks with the pro kit. how much is that lowered and did you get any other suspension parts such as camber kit or struts?
Old 02-05-2002
DogstyleEX's Avatar
Nope i didn't get anything else.. but as you can see from the pic i can use a rear camber adjustment... the ride is pretty nice... although going slow over huge *** bumps help a great deal.. i just did the springs for now.. i've hit some huge bumps.. and hard too.. and my shocks are good..i've actually ramped my car off a huge dip in the road (by accident of course) prolly caught some air, and they're still good
Edit: it says that it lowers .8 inch, but i doubt that.. looks more like 1.2 to me..
Old 02-05-2002
Bartkat's Avatar
I've got pro kit ordered. I'll try and measure before and after. I'll also see if my tire guy can align it without any camber kit before I take it out. Glad to hear your stock shocks are working because I want to wait for Tokico before I change shocks.
Bartkat is offline
Old 02-05-2002
UncleB is an unknown quantity at this point
you car looks nice. now I know what I can expect from mine. thanks!
UncleB is offline
Old 02-05-2002
dogstyle, do you have any side view pics?
Old 02-05-2002
CrackRockSteadyCivic is an unknown quantity at this point
I'm confused about Eibach springs and their camber kits. For example, Dogstyle has pro-kits(~1.0 drop) and from the pics he also has a pretty bad negative camber problem in the rear. Now check out ALLMAN'S ride on the first page of member's rides. He is sitting on Eibach Sportlines(~1.5-1.8 drop) and he has no camber problems and doesn't have the camber kit installed! Isn't this a little weird? ALLMAN has a lower drop than Dogstyle and has no camber problems! Are Eibach springs inconsistent???
CrackRockSteadyCivic is offline
dtdoyle
25
08-30-2015 07:57 PM
redcloud
25
08-12-2015 02:23 PM
Curtchuk
08-05-2015 03:14 PM
JKWood
07-28-2015 04:45 PM
Fred65
Wheels and Tires
07-14-2015 07:40 AM
Quick Reply: LOWERING A SEDAN
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
