DIY:Racing Seat with OEM bracket/slider install guide
Old 04-19-2005
X-R8ED's Avatar
X-R8ED is an unknown quantity at this point
Old 04-19-2005
wonderz's Avatar
wonderz is on a distinguished road
hehe, pretty sure if its direct bolt on, most ppl have already done it by now.
so yeah, you will need buy some sparco bracket and sliders unless you wanna mod your oem ones.
Old 04-19-2005
7thgen Power Maker
dezod's Avatar
You need aftermarket brackets and sliders.
Old 04-20-2005
X-R8ED's Avatar
How much???
Old 04-20-2005
Fiji Club Member
HondaGuy12's Avatar
u need new ones.. im installing mine right now using my stock ones..but you have do the following...
1. Remove the stock brackets for ur stock seats ( by either banging them off or using a drill bit to drill through the bearing the realease them pain in the ***)
2. Find some short of bracket/connecter to mount ur stock brackets to ur new sliders
3. Get a metal extension to fill the gap to the holes on the floor( the new sparcos are alil more thinner then stock seats and there is a gap that will need to be extending to reach the bolts)
(If not using harnesses)4. Take off ur oem seat belts carefully and drill them into ur new Torinos or metal bracket. connect the srs if you have them back to the seat belt.
Old 04-20-2005
Type Skivic
TeRRoRiFiC35's Avatar
Location: Old Bridge, New Jersey/ West Virginia University
TeRRoRiFiC35 is an unknown quantity at this point
is that a plane in ur sig?
Old 05-15-2005
X-R8ED's Avatar
Installation guide for Racing seats w/ OEM brackets & sliders
a GUIDE, I found this @ honda-tech, I was thinkin of doing this, but this guy already made a guide with pics & measurements, helped me out and saved me a few hundred in the process, very good DIY. Just take an extra 5 mins to double check all the measurements on your particular app b4 cutting/drilling.
Old 05-15-2005
X-R8ED's Avatar
Oh and maybe this post should be moved to tech now, since it has some technical info now.
Old 05-15-2005
zen_master's Avatar
is 2002 SI seats are (direct) bolt on to our car? how about 00SI? do they fit perfectly?
Old 05-15-2005
X-R8ED's Avatar
they should, but Ill double check with my buddys 99 sir and my brothers 02 sir, and Ill get back to you in a bit. I think TeLLy from the EL section has the 02 SiR seats in his ride, and if i remember correctly he just bolted them in.
Old 05-15-2005
X-R8ED's Avatar
Ill post actual pics
I post actual pics of our mounts, the plate, and the whole thing being assembled and complete. Save & open for better quality.
Name:	02 vic torino mount plate.JPG
Old 06-19-2005
newyoricancivic's Avatar
newyoricancivic should not be trusted
so do the 02 si seat bolt into ower cars direct need to no i picking up a set in a couple of days
Old 06-23-2005
diskreet's Avatar
just in general how do you get the stock seats off? I may need this kind of info soon.
Old 01-25-2007
alarcon88's Avatar
alarcon88 is an unknown quantity at this point
so do they?? i kno this is a bit old but i would like 2know
Old 01-26-2007
X-R8ED's Avatar
If you have a 7th gen coupe/sedan the seats from an 02-04 Si/SiR hatch will directly bolt-in to your car for sure any other generation Im not sure on.
Old 01-26-2007
SEN_ONE's Avatar
SEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of light
^The SI seats will fit, but you have to drill out one hole on each seat to make them line up to bolt down.
Old 01-26-2007
roll_outz's Avatar
roll_outz is an unknown quantity at this point
absolutely not direct bolt on.. the 02-04 SiR R totaly different from 7th gen civic.. only 3 bolts R line up but U have to do some mods for the 4th bolt.. gud luck...guys...
carid
06-10-2015 09:57 AM
RIPSAW
06-09-2015 08:33 PM
reqy
06-01-2015 07:05 AM
Blazz
05-25-2015 10:56 PM
Youshoe
05-22-2015 09:36 PM
Quick Reply: DIY:Racing Seat with OEM bracket/slider install guide
