Sponsored by:
Sponsored by: CARiD
what does the r34 kit REALLY look like?
Old Nov 1, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
Question what does the r34 kit REALLY look like?
I'm looking into getting an Octane R34 body kit (urethane, of course). The only problem is, in some pictures I've seen the side skirts look completely attrocious. However, in others, they look good. I need to know how they really look; because I might be getting some different skirts if they look like the terrible one.
Here's a picture where they look good:
http://nopionline.com/index.cfm?fuse...aneBodyKit.jpg
And here's a picture where they look bad:
http://thecivicstore.com/Merchant2/m...ry_Code=OCTANE
Don't tell me they look the same; in the first one they look straight up and down, while in the second one they're DEFINITELY sticking out to the side obsenely. Anyone with this kit, please tell how it really looks!
Old Nov 1, 2003
RedDragon333's Avatar
from all the kits ive sen they look like the first one. Ive seen three in person and they all look pretty flush. If i could however make a suggestion i wouldnt get the OCtane sides unless your mold them to the car. Might want to look into somethng else that will go with it. However if you chose to go with the OCtane sides they look like the first pic.
Old Nov 1, 2003
jwalker87's Avatar
Bodacious Member
THANK GOD I really like the first pic; molded or not. I was just scared away by the fact that it MIGHT look like the second one....ewwww...i don't think thecivicstore.com will be selling too many of these.
Old Nov 1, 2003
abmerop18's Avatar
Jam out with your clam out.
ya i have seen both also. i think there are actually some members on here with the second set. i personally like the first better and when i get mine i am defeniatly gonna mold them, it looks so much better and give kind of a wide body look.
Old Nov 1, 2003
jwalker87's Avatar
Bodacious Member
so whats the difference between the two? They look like the same kit...is it a different way of mounting it? if so...definitely first one. Gonna mold it when I get the money...definitely not right now.
Old Nov 1, 2003
abmerop18's Avatar
i think the difference may be the vents and the fact that the second one doesnt go up as far in the back part of the skirt.
Old Nov 1, 2003
abmerop18's Avatar
or maybe even the difference is they had different molds for the fiberglass and urathane (sp?) models of the side skirts. that may be it.
Old Nov 2, 2003
jwalker87's Avatar
Bodacious Member
so how do I make sure I get the first one?
Old Nov 2, 2003
SMURF_KILLER's Avatar
SMURF_KILLER is an unknown quantity at this point
I bought the R34 kit but I really don't like the side skirts so im selling them but the front bumper and rear look really nice
Old Nov 2, 2003
oh and don't go with VIS I have it and I have to do a lot of changes to it, I got it with a lot of cracks and missing corners etc, so I have to bring to body shop to get MAJOR work done
Old Nov 2, 2003
Pharoh's Avatar
Bobaganoosh!
I love the R33 front! But I don't like any kit that has two exaust outlets in it.
My choice is to use the R33 front with Kaminari sides and rear.
Old Nov 2, 2003
XxSoVeReiGNxX's Avatar
The kits look the same. However the white civic in the second link, it looks like the install was very poor. The fit of the sideskirts were probably not so good, but instead of trimming down the inside (where the sideskirt touches the body of the car), they installed it without caring.
Old Nov 2, 2003
jwalker87's Avatar
Bodacious Member
ok; what someone said about it cracking; did you get fiberglass? From what I've heard from many places is that fiberglass cracks and chips like crazy; thats why I'm going with urethane. And if the difference between the 2 pics is just install preference, then I'm good. I don't really like the look of the r33 though, its r34 for me.
Old Nov 2, 2003
R34 is a really good choice I like it and yes I got fiberglass because I couldn't afford the urethane at the time, but yes good choice with the urethane I wish I got it in urethane too
Old Nov 2, 2003
jwalker87's Avatar
Bodacious Member
by the way, by "major work" on your body kit, how much money are you talking about?
Also, what material are the stock front and rear bumpers made out of? just for reference.
Old Nov 2, 2003
centurioncivic's Avatar
centurioncivic is an unknown quantity at this point
i have the r34 kit and love it. i put the kit on myself and it is flush with the car. the white civic is just a poor install job. my kit is fiberglass and was cracked and chiped bad when i got it. the body shop fixed it and painted it for 400 bucksa though cuz i knew the guy. I believe that if you get the urethane r34 kit the sides dont go up as high as the fiberglass sides. hope that helps.
Old Nov 2, 2003
jwalker87's Avatar
Bodacious Member
k. You said fixed AND painted for $400...how much do you think it would run for them to paint it? Just standard Honda REd.
Old Nov 2, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
that white one looks retarted.. im relaly hoping that was an early prototype or something. cuz the octane / r34 kit looks but better than that if professionally installed.
Old Nov 2, 2003
jwalker87's Avatar
Bodacious Member
i think some guy earlier hit the nail on the head; its all in the install. If you install if half-assed, the end result is fugly. If you either take your time and do it right or get it done by a pro, then it looks swiggen. By the way; which would you recommend? Is it worth the money to have it installed, or should I do it myself. If I did it myself, I would be sure to spend the extra time to get it looking like the first pic.
Old Nov 2, 2003
Test fit it yourself (fix the pieces, so they fit perfectly). Then go to a shop and get it painted. Then you can bring it home and install it yourself. It's just a few screws, brackets, and double sided tape that hold it on.
You have to test fit it because if there is a part that you want to trim down after it has already been painted, that is bad news
Old Nov 2, 2003
jwalker87's Avatar
Bodacious Member
how much would you estimate the painting to cost?
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
beanhead
Sep 24, 2015 12:04 PM
