2013 Honda Civic Shakes Violently When Braking With Traction Control Is On
Rep Power: 0 2013 Honda Civic Shakes Violently When Braking With Traction Control Is On
Any ideas?
When I turn my traction control off; However, the car runs smooth as butter.
When it’s on, the car violently shakes when slowing down or when applying the break. When I push down on the break, I can feel the rattle especially.
Re: 2013 Honda Civic Shakes Violently When Brealing With Traction Control Is On
Any recent work done, shortly before this started happening?
Got ABS, VSA, and/or triangle warning lights on? Got fault codes?
Mismatched or incorrectly sized tires?
Rep Power: 0 Re: 2013 Honda Civic Shakes Violently When Brealing With Traction Control Is On
And I have absolutely no warning lights, VSA ABS or triangle warning.
But I havent plugged in a sensor to read any fault codes. I had a mechanic plug in a sensor but he didnt mention anything about any faulty codes but no, I myself have not plugged a scanner in since I dont have one.
Im not sure, I mean like I said, I drove the car before taking it to the shop, the problem only arose after. Perhaps they scammed me??? This came to mind when the problem came
up because I wasn’t sure if the mechanics may had done something purposesly but I just decided to throw that thought away.
Received 1,440 Likes
Rep Power: 338 Re: 2013 Honda Civic Shakes Violently When Breaking With Traction Control Is On
take it back to the mechanic.
PS: it spell brake.
if break, it's broken...
PS: it spell brake.
Rep Power: 0 Re: 2013 Honda Civic Shakes Violently When Breaking With Traction Control Is On
but also, it wasnt a mechanic, it was just a body shop.
Well, I bought the car as a salvage title.
Were any SRS components deployed in the crash? What's been replaced?
Any replacement Bearings/axles/wiring?
I'd suspect a bad encoder on a bearing, or a cluster sensor initialization problem, or the steering wheel position sensor isn't clocked correctly, something along those lines. I expect something is making ABS/VSA react incorrectly to braking efforts.
msohag
03-21-2015 02:09 PM
Lordscivic
02-26-2014 12:54 PM
sleekcivic2004
02-19-2006 01:00 PM
