Door switch malfunctioning
Old 11-06-2017
dalinjs's Avatar
dalinjs is an unknown quantity at this point
Hello all!
I couldn't find an answer to my specific situation anywhere, though I apologize if this has already been asked and resolved.
Since a couple of days ago, the door ajar light on my 2007 Honda Civic has been very finicky. Even when my driver side door is shut, the light will illuminate. If I shut the door a little harder than usual, the light will go off, but as soon as I nudge the door with my knee or go over a bump, the light comes back on. When the door is shut and I pull on it harder, the light will go off again.
The weird thing is when I use my finger to depress the door switch, the light stays off with no issue, even when I move my finger around. Even when I barely push the switch, it will not falter.
Old 11-06-2017
Re: Door switch malfunctioning
See if the door sticks out a little more than it should when closed.
Maybe the striker plate (loop) is in need of adjustment to pull the door inward a smidge.
See if there is a rubber or plastic pad missing where the plunger of the switch makes contact with the door (compare to the opposite door)
