Aftermarket backup camera installation - 2014 LX sedan
Rep Power: 0 Aftermarket backup camera installation - 2014 LX sedan
Hello everyone!
I'm trying to install a backup camera in my 2014 LX sedan. I'm trying to test the camera and wiring first to make sure everything is right before I commit to attaching this thing.
My setup: I have a DOD RX400W dashcam already installed (has been running/working for 6 months now ... no problems there) and it's powered to the fuse box. This will act as a screen for the backup video too. The dashcam has a connection on its top for an aftermarket backup camera to plug into.
I've tried loosly connecting everything but it didn't work. Here is my problem (see picture with A,B,C,D,E). This is a picture with the camera (A), the trigger wires (B), the rca connection (C), more trigger wires (D) and finially the wire that plugs into the dashcam to supply video (E). The reason why there are two trigger wires is because the dashcam came with its own wiring to connect a camera (has trigger wires) and the aftermarket camera came with its own wiring to connect to the camera (has trigger wires). :P Anyways, the only way to connect everything is like in the picture provided. Maybe this is why I can't get a picture to show because of having two trigger wires with only being able to use one? If so, would cutting away the first trigger wire (B) and splicing the lines together work?
My next question refers to the second image: The reverse light harness. There is a brown wire and a black wire. How do I connect the trigger wires to this? Connect the red wire from trigger to brown wire of harness and black wire from trigger to body of car (ground)? Is it possible to remove a wire from the harness and twist the needed wires together and then re-insert them? Or should I buy a t tap and connect into it that way?
I appreciate any help on this. I'd really love this get this camera up and running (only when reversing, of course :P)
Steve
Steve
Re: Aftermarket backup camera installation - 2014 LX sedan
Doesn't the car come with a back up camera from the factory?
Rep Power: 0 Re: Aftermarket backup camera installation - 2014 LX sedan
I have the Canadian model. I believe the American LX had a camera but not mine.
the trigger wires ...
... more trigger wires
I might guess one trigger is to tell the dashcam to switch the image displayed to the rear camera,
and at the same time I can visualize the camera itself requiring a power and ground source to operate
both of which would probably come from the 12v backup light bulb circuit.
Black is 12v-
T-tap (with spades) is ok, so are Scotch Locks, but keep in mind they aren't the greatest and some time down the road (may be weeks, or may be several years) they may not provide good solid electrical connections.
They are quick and easy to install, but sometimes difficult to diagnose random intermittent problems caused by them.(a nightmare when an installer used many of them)
If I were making a permanent install, I'd probably use crimped spade or even soldered connections.
Ah, I didn't realize this.
Multiple trigger wires, you may want to check documentation or contact support for your dashcam and backup camera if possible for clarification.
Brown is 12v+
Black is 12v-
Brown is 12v+
Black is 12v-
Hmm, I just thought of something. To test out my "too many trigger wires" theory, if I can find another AV cable to connect to my HU that doesn't have it's own trigger wire. I'll have to see what I've got.
As for connecting the trigger wire to my reverse lights, do I connect + to + and the ground to the car?
And the fact that I have two trigger wires doesn't help.
I don't have your instructions, but it seems to me both red and black pairs would all connect to the same power and ground source (reverse light wiring)
The RCA (video signal) could be considered an independent system (signal) separate from the powers and grounds, it merely resides within the same bundle of wiring
Either way works IMO if it will satisfy the requirements of your accessories.
Also, see this video -
I've seen this video and diagram before but they didn't make sense to me until you suggested wiring both triggers (one as power, one as a trigger).
It's been pretty hot here these last few days (and to come) so I won't be able to test these suggestions out for probably a couple days. I will reply with my results when I can.
At the cars' reverse bulb harness:
Brown is 12v+ (switched; only powered when the light is on)
Black is 12v-
So....
connect both red wires to brown (switched 12v+)
connect both black wires to black (constant ground (12v-))
only connect to one reverse light harness. No reason to string wires across the trunk to both.
When you run wire to the camera in the trunk lid (assuming you place it near the license lights), leave a long loop at the hinge area to reduce stress from flexing every time you open the trunk. When I did my backup cam the first time I followed the stock harness and release cable but the wires in the camera harness broke from flexing after just a couple years. Now I repaired it and gave it a lot of slack in that area.
Black is 12v-
So....
Thank you for the clarification of how to connect the wiring. I'm always afraid I'm going to fry something. 😛 Had to make sure.
That's a good tip, leaving extra wire at the trunk hinge to alleviate stress in the wire!
I'll let you know how things turn out when I get the chance to work on it. I appreciate ALL your help and the quick replies. 😊 Customer service reps, take note! lol
So I tried as you suggested - I twisted together the red to red and black to black and connected those to the reverse bulb (I just pulled out the harness and stuck the wires into the sockets ... is that ok?), put the car in reverse but no picture on my dash cam. 😞 I did notice that after doing this, when I removed the connector (2.5mm jack) from the dash cam, the screen sometimes would turn blue or black with swiggly white horizontal lines. I would then have to manually power the unit off and on to get the front camera to display it's picture. Is this any help or just add to the frustration? lol
That doesn't sound promising LOL
Remember, I can only guess from my recliner and looked at the little diagram you attached in post #7, you have the actual electronics in front of you (or in the car)
Visit the websites of whomever made the dashcam and whomever made the backup camera? Can you find a troubleshooting guide or more instructions?
Had some spare time today and thought I'd give it another shot. I got a suggestion from a guy in YouTube. It was pretty much what you suggested, just the power source I connect to had to be constant. So the camera wires (B) connects to a constant power source (something that gets power when the car is turned on) and the other wires that come from the dash cam (D) connect to the reverse bulb harness (trigger wire).
At first the camera wasn't connected to a constant power source and the dash cam would change screens when put in reverse but it was solid blue. Once I connected it correctly to a constant power source, I was like Jim Carrey in Ace Ventura, "It's allllive! It's ALLLLIVE!"
Thank you SO much for your help ezone!! 😁
