LED Running Lights
Dr Krieger of Modification
Re: LED Running Lights
They do, ebay.
Find your OEM bulb number type, just go to a local parts shop for help, then type that number into ebay with LED.
For example my car lamps take an H1 style bulb. so I types "H1 LED bulbs".
There are a few things to think about though. If your DLRs are a combo bulb with the Highbeam, you will be running the same brightness for both. So if you go with a cheap LED with low light output, your high beams may also have low output. If you use high Lumin output bulbs then your DLRs will basically be highbeams.
Rep Power: 0 Re: LED Running Lights
Thank you Mac, though, I purchased some lights from SuperBrightLEDs.com and installed them. Now, I'm receiving a DRL message I'm sure is related to the LED load. Therefore, I either need to put back the old bulbs or install load resistors which I'm checking into now.
Nalmonte
11-17-2015 12:55 PM
