WTF Wiper blades?
Rep Power: 0 WTF Wiper blades?
So yeah... A little stumped here with my wiper blades. I have a 2008 LX 4 door. I went to put on new wiper arms with blades and realized that they look different and the style of rubber does not swap on there either.
What exactly do I get and from where?
Anyone have part numbers or anything else that could direct me into the right direction?
Received 1,440 Likes
Rep Power: 338 Re: WTF Wiper blades?
as a starter, What did you buy? Did you ask for wipers for your car or another? where did you buy? If dealer, should be pretty much the same if you asked for the right car.
Are you having trouble to fit them? Can you not install them? Not all wiper blades are the same, you know... they could be different is standard fit aftermarket...
And if they can be installed there and they are the right length, what are you asking for again?
Confused... Not really trying to be harsh, but having a hard time understanding what is your question...
If you want to replace the whole wiper blade (frame and rubber refill insert) as opposed to changing just the refill insert, take a look at Trico NeoForm Beam Blades. They work awesome and fit on most years/models of Civics. Right now they have rebates running and you can get them for about $15-$19 a pair depending on size after rebates. I like changing the whole wiper blade rather than just the rubber refills because I live in the ice/snow belt and my wipers go through a lot of abuse. I figure better safe than sorry. I don't go to the dealer though - too much $$$$.
I'm going to give the factory 8th gen blades a try this winter, most likely will get a new set of refills before then.
I always hated how my 7th gens original blades would freeze and not work well & also I did not like the fair weather operation of my winter blades so I went back & forth a lot.
Rep Power: 219 Re: WTF Wiper blades?
Do you think it will fit our 7th gen? I am not quite sure about the clearance when those blades move. The driver sides is 26" while the passenger is 23". The ours is just 21" and 19". By the way, I just bought the Goodyear's wiper blade from the Costco. I think it's about $8 a piece so it's not that bad for the price.
However, with the blade style. I noticed that top of the blade couldn't completely touch the windshield at the normal position (passenger side) compared to the normal wiper.
If the 8th fit the 7th gen, I will be very happy.
I have tried Bosch, Anco and this Goodyear is my third set. Anco served me well. Bosch was the worst and the most expensive but I suspected that Autozone kept it for so long that the rubber might go bad already. I haven't used Bosch since.
CraigW,
I searched each model's wipers have found that the length of wipers :
Accord 2010 Passenger Blade set (475mm)
Odyssey 2010 Passenger Blade set (550mm)
7th gen has 525mm (driver side) and 475 (passenger)
I am thinkin...
h4ldol
04-24-2017 08:16 PM
meicalnissyen
09-25-2015 12:12 AM
hatch90
09-03-2015 08:45 AM
