Need assistance determining what wheel cover size I should buy.
Rep Power: 0 Need assistance determining what wheel cover size I should buy.
Hello. I'm not a car person by any means but I recently became interested in making my 2012 civic look acceptable again.
My wheel covers are bent, scuffed, and make the whole car look like trash. So I found a new set on Amazon but I'm struggling to determine which size I need.
When I measure the current wheel covers' diameter, I'm getting exactly 16 inches. But, the tire itself has the code "65R15" and I've read that the number "15" in this case determines the size of the wheel cover I should get. I'm hoping to avoid the pitfalls of being uninformed, so I wanted to check with you guys and see if anyone here knows what size wheel cover I need. Including a picture of the tire in case it helps. You can get a sense for how severely I've damaged the factor covers too... >_>
Tangent, but I'm also curious when one would know it's "time" to replace the wheels entirely? I'm open to doing this if necessary.
Received 1,440 Likes
Rep Power: 338 Re: Need assistance determining what wheel cover size I should buy.
you need a 15.
the tire opening is 15.
The wheel total need to be bigger than 15 to hold the tire in place. so it's like 16. We still call them "wheel to fit into 15", for the bead seat diameter is 15, and it simply would be too confusing to have 16" wheels to fit 15" wheels.
the wheel cover, well, need to cover the wheel, so.
Received 1,122 Likes
Rep Power: 190 Re: Need assistance determining what wheel cover size I should buy.
Need 15" covers as Sandro said.
The rims don't need to be replaced unless they are damaged.
You can sand them and paint them if you want to make them look new
Prelude Owner
As soon as possible lol. No really unless there is something wrong with them (bent, rusted) there really is no reason to replace them. You can look on craigslist though and find decent OE alloy wheels for a good price used. Makes a big difference on appearance IMO.
Rep Power: 0 Re: Need assistance determining what wheel cover size I should buy.
Thanks for the response all. I ordered some 15 inch covers and will probably make a project of cleaning off the rust over the holiday.
bumping this because i have a new question on the same subject.
so i got my new 15 inch covers but have since discovered that the old ones are attached to the steel wheels via the lugnuts. and i dont have the means to remove these myself. so my question is.. who do i call for assistance removing the current wheel covers? would this be something i go to autozone for or should i visit an actual garage? again im a car noob.. my old neighbor was a mechanic and a saint and would help me with all this stuff but that dude passed away in October... so hoping i can find answers here.
Prelude Owner
Your car has everything in that you need and the owners manual shows you the jack points.
Get your scissor jack and lug wrench out of the trunk.
If you do not feel comfortable doing this then a garage would be best. Maybe wait until you need tires or an oil change to save some money.
bumping just to show off the massive difference and to thank you all again for the help.
my brother came through to help me get the old covers off . After cleaning the wheels and snapping on the new covers, the car looks almost as nice as it did new. very happy, thanks folks!
my brother 😀
wheels scrubbed clean with new covers!
my brother 😀
Received 1,144 Likes
Rep Power: 485 Re: Need assistance determining what wheel cover size I should buy.
For future reference, here's how to read tire sizes, using 195/65r15 as a reference
• First number (195) is the treadwidth in mm (195mm wide)
•Second number (65) is the sidewall profile, as a percentage of the treadwidth (65% of 195mm, so the sidewall would be 126.75mm high)
• Third number (15) is the diameter of the wheel on which the tire fits (15" rim)
hiroaki
12-01-2005 08:26 AM
