Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
2012 EX-L TPMS Question
Old 06-08-2018
Atomic Robot's Avatar
Atomic Robot is an unknown quantity at this point
Got this Civic a few months ago from a Honda dealer and this is my first time experiencing an issue with a TPMS system. The low pressure light came on, so I checked the tires. One tire was slightly low and I refilled all to the 32psi spec on the door. This is the part I haven't been able to figure out...
I looked at several videos on how to do a TPMS reset but there doesn't seem to be a menu item for it. These are the menu steps I found-
1- Vehicle Information <OK>
2- Maintenance Info <OK>
3- Customize Settings THIS SELECTION DOESN'T EXIST.
4- TPMS Calibration
I also tried 1- Vehicle Information / 2- Customize Settings, but there is no TPMS Calibration selection there either. I scrolled up and down through all the menus.
What am I missing here?
The tires were newly replaced by the dealer if that makes any difference.
Old 06-08-2018
Re: 2012 EX-L TPMS Question
2012 has pressure sensor inside each wheel. There is no reset menu. See your owners manual.
After airing the tires to correct pressure, simply drive the car above 25 mph and the warning light should extinguish.
Old 06-11-2018
Thanks- that fixed it. Couldn't find anything in the owner's manual- that's how I ended up here.
ericsharp
Electronics
11-09-2020 01:31 PM
xiariwuyuan
09-19-2017 06:58 AM
crimson_pearl
12-10-2014 06:36 PM
Timbogates
09-13-2014 07:55 PM
Mantaray14
01-03-2012 04:58 PM
Quick Reply: 2012 EX-L TPMS Question
