08 honda civic-body shakes while breal is applied travelling downhill
Rep Power: 0 08 honda civic-body shakes while breal is applied travelling downhill
hi
a weeks back tried to change rhe break pad but when opened everything found the pad about 60% ok so fixed it as it is. Yesterday while deiving back home sownhill drom cypress, when applied break at 70 noticed whole body was shaking. At 50 the same. While i was in plain dint observe this though.
any suggestions what is wrong.
Received 1,122 Likes
Rep Power: 190 Re: 08 honda civic-body shakes while breal is applied travelling downhill
If you get a vibration when breaking usually the rotor is warped or something is sticking
Rep Power: 0 Re: 08 honda civic-body shakes while breal is applied travelling downhill
Thanks Colin.
i also thiught so, but when i opened the caliber and checked the rotor, at high dint seems to ve warped. But i might be wrong with my observations. Probably need this mexhanic tested.
will let you all know.
You won't be able to tell it's warped just by looking at it, unless it's really messed up.
Received 1,144 Likes
Rep Power: 485 Re: 08 honda civic-body shakes while breal is applied travelling downhill
Yep, could be just a couple thousandths run out. Machine shop with dial indicators (unless you got your own and know how to measure runout) should be able to tell you no problem
zxzkilme
10-26-2013 07:31 PM
blackhondacivic
08-25-2012 12:34 AM
aZnVoYCe
04-22-2003 02:06 PM
