Lost PCV valve washer
Rep Power: 0 Lost PCV valve washer
Hey it fell somewhere I can't get to it. Can I screw it on without any washer. To go try and buy one later. The one I ordered didn't come with one.
Or can I put just a little Honda bond on the PCV valve ring and just screw it, I guess the point is to have no leak, or does the washer make it more tight, I feel with no washer I can screw a lot of turns.
Re: Lost PCV valve washer
If the washer is what I'm thinking of, it uses the same soft aluminum oil drainplug washer. Use a Honda oil drainplug washer.
Received 1,144 Likes
Rep Power: 485 Re: Lost PCV valve washer
Yeah, just buy some oil pan crush washers. Its a good idea to have a supply of them if you do you own oil changes anyways
Ratpick
05-27-2014 03:50 PM
mlandmann
04-26-2013 01:58 PM
Storm897
05-13-2005 06:30 PM
scatman
05-09-2004 09:01 PM
