Malfunction indicator lamp light / fault code P0847
Old 03-17-2018
sdraza1's Avatar
sdraza1 is an unknown quantity at this point
I am having malfunction indicator lamp light coming on intermittently. I went to master mechanic and they gave me error code P0847 and told me to get transmission checked but the honda manual says it is transmission problem. Where should I go to get it fixed? thanks
Old 03-17-2018
Re: Malfunction indicator lamp light / fault code P0847
Type your fault code into the search bar and hit enter: civicforums.com/search
The majority just need the appropriate pressure switch replaced
Old 03-25-2018
sdraza1's Avatar
I went to a mechanic who said it is better to change the whole transmission (by a used transmission, total cost $1000) rather than change the pressure sensor as the latter may cause problem to recur. I asked him what if I left it as such. He said it was ok and it wouldn't cause any harm.
Old 03-25-2018
Wouldn't you rather only spend USD 73 on a pressure switch that might take 15 minutes to replace? (or however much one of those costs, plus its gasket)
Seems like a no brainer to me.
Trans shifts okay, yes? Trans does not need replaced.
Replace the pressure switch to fix the problem.
Old 05-26-2018
sdraza1's Avatar
I didn't do what you suggested not because that I don't trust you but because I have been so busy I couldn't go to mechanic but my honda civic is working OK, The same fault icon showed up before too, perhaps 1 year ago and then disappeared and it has disappeared this time too. Just wanted to tell you my experience and say thank you to you.
Old 05-26-2018
Yes when they first fail the problem is usually intermittent. The occurrence may eventually become more frequent.
Be prepared to replace the pressure switch to resolve the issue.
bluericeburna2k2
06-08-2009 07:26 PM
fastcivic03
06-01-2004 01:20 PM
keffin
01-03-2004 07:20 PM
mongo
05-23-2003 02:00 PM
rp
10-04-2002 04:24 PM
Quick Reply: Malfunction indicator lamp light / fault code P0847
