Interior Post information/questions/Issues about Interiror Parts here.
Horn Issue
Old 07-24-2015
kaashifv's Avatar
kaashifv is an unknown quantity at this point
Horn Issue
Hello,
Just picked up a 2012 Honda Civic LX, and when i press the horn on the leftside and middle of the steering wheel the horn works. If i press to the right side of the wheel the horn does not function. I took it back to the dealer and they said as long as the horn works it passes safety and they are not liable to fix it.
Anyways, how can i pull the switch out to check it? I bet i would have to remove the negative connection, wait about 5 mins and then take off the two screws on the side of the steering wheel to access the switch, can anyone please confirm this?
Old 07-24-2015
mikey1's Avatar
Re: Horn Issue
wow....you must get mad at a lot of people while driving
Old 07-24-2015
kaashifv's Avatar
Re: Horn Issue
Hahah, it was like that when i picked it up
Old 07-24-2015
Re: Horn Issue
Remove 2 Torx bolts (T-30) holding the air bag to the steering wheel.
Remove the bag from the wheel.
Then you can inspect.
Old 07-26-2015
kaashifv's Avatar
Re: Horn Issue
Thanks for confirming. Turns out the swith was sticky. I cleaned it with contact cleaner and it works now!
Old 07-27-2015
CraigW's Avatar
Re: Horn Issue
^^^ Pepsi Syndrome....
Thanks for updating!!
Old 07-27-2015
Re: Horn Issue
Originally Posted by CraigW
Pepsi Syndrome....
"Only a handful of people know what the Pepsi Syndrome means. Maybe soon, everyone will know it."
Old 07-27-2015
CraigW's Avatar
Re: Horn Issue
It has been a while.... Yes, many will not understand.
Old 07-27-2015
mikey1's Avatar
Re: Horn Issue
some of us do
sbi
11-29-2015 12:07 PM
brklynboy
08-08-2005 11:50 PM
xHoteKx
04-02-2002 09:45 AM
zlander
03-28-2002 08:50 PM
CaptainAmerica
01-18-2002 08:30 PM
Quick Reply: Horn Issue
