2006 Civic Engine block crack KNOWN DEFECT - Honda Civic Forum
View Poll Results: Any experience with Overheating damage on Honda Civic 2006-09
Yes...replaced engine and all related
0%
Accident with undiagnosed cause
0%
Honda refused responsibility
0%
Still dealing with it
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Old 04-21-2015
Xuhme is an unknown quantity at this point
Exclamation 2006 Civic Engine block crack KNOWN DEFECT
Driving 2006 Civic and experienced sudden engine shutdown...absolutely no warning or check engine light, and temp gauge showed normal...at moment of shut down, two lights flashed--oil pressure and fluid warning...drifted off road despite unable to steer or use brakes. Had car towed to dealer. While waiting for tow truck, checked fluids and the coolant was empty. I trying to turn car on, temp showed hot...after stopping.
Honda had issued an extended warranty on block, the crack is a known dfect in this generation...and will replace engine, but NOT head, dipstick etc....all collateral damage attributed to our driving in an overheated condition...which DID NOT HAPPEN. $2,000 to replace collateral damages...90,000 miles (extended warranty to 100,000 miles purchased, but expired after 8 years). original owner. Wondering how many accidents have occured due to engine failure but it was not diagnosed due to collision after the failure? Never one moment of mechanical problems...always serviced by Honda dealer--last service two weeks prior and no hint of a problem (oil change, fluid checks). Looking for anecdotal and specific experience. Car Complaints.com has 150+ examples of this problem...
Xuhme is offline
Old 04-21-2015
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
Re: 2006 Civic Engine block crack KNOWN DEFECT
Did you call the American Honda number, or are you just going through your dealer?
(Assuming you are in the U.S.)
http://automobiles.honda.com/informa...relations.aspx
jordan1794 is offline
Old 04-21-2015
Also, just saying, there are 7 million 8th gen honda civics in the u.s. alone.
150 complaints is very, very low.
It's a known issue, and it's been covered here in the forum before...
https://www.civicforums.com/forums/1...-cracking.html
Again, I'd contact Honda corporate, they will be much more helpful than talking directly to the dealer.
EDIT: I also cannot imagine a scenario where an engine failure would cause an accident that could not be tracked afterwards...
If an engine drops your pretty much are just coasting, unless you are on the highway it's a rather "safe" failure to have. Even on the highway, I'd imagine the damage would be focused purely on the rear from the idiot who was following you too close anyways.
Old 04-21-2015
$2,000 to replace
Gee.
At my dealership we have had no problems replacing whatever is needed to restore the vehicle to a normal operating and reliable condition, all covered by the warranty extension on the engine block.
That includes the cylinder head if it is warped badly enough need replaced, the melted dipstick, melted ignition coils, we have even replaced a couple of radiators that were damaged during the overheat events. All covered by the warranty extension, customers did not have to pay a dime out of pocket.
Additionally, the warranty may pay for a rental car while we do the work.
A factory rep might need to give authorization in order to get all this covered by the warranty.
Contact Hondas customer assistance.
You are ALWAYS able to steer and use the brakes.
It just requires more physical effort on your part after the engine quits running because the power assist disappears.
ezone is offline
CarStuff
10-11-2018 01:29 PM
usajags84
05-10-2015 09:11 AM
MN-02-CivicEx
28
05-02-2015 10:11 PM
Linda0818
04-23-2015 12:30 PM
Quick Reply: 2006 Civic Engine block crack KNOWN DEFECT
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
