Windshield Wiper Problem
Rep Power: 0 Windshield Wiper Problem
I have a 2006 Honda Civic. Over the last couple of months, I have developed an intermittent problem with the windshield wipers. Examples of this include:
- When I click it to just wipe once, it will wipe multiple times an sometimes (though not always) stop in a position other than "parked," such as fully up along the sides of the window or anywhere in the middle.
- When I have them on the lowest intermittent setting, instead of just wiping once every so many seconds, they will wipe two, three or more times and then sometimes stop not in "parked" as described above. The same things happens at higher speeds, though not in the normal (constant) or high speeds.
This only happens when it is raining/snowing - and not just because that's only when I have them on. I have let them run under dry conditions and they works normally. So I am guessing there is a short somewhere that it being affected by the moisture?
Any suggestions what might be happening and how I can fix it would be appreciated.
Thanks!!
Thanks!!
Re: Windshield Wiper Problem
Not anymore. The switch plate is available by itself for the 4 door car.
$15.52 retail
Linkypoo: http://ww2.justanswer.com/uploads/hy...ot_parking.pdf
$15.52 retail
Thanks!!
Thanks!!
Super Moderator
Received 1,841 Likes
Rep Power: 196 Re: Windshield Wiper Problem
10 year old thread. Start your own.
Received 1,440 Likes
Rep Power: 338 Re: Windshield Wiper Problem
you have a solution posted out. Have you at least tried it before asking?
ClapAlongChorus
Electrical
10-28-2021 10:50 PM
Domindart
06-04-2015 09:20 PM
Killagi
05-14-2015 10:08 PM
ZSKCivic01
11-04-2001 08:47 PM
2000, 2005, 2007, civic, fuse, honda, issue, motor, problem, recall, system, transmission, windowshield, windshield, wiper
