View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
#2072
Re: Torque converter question
Life lesson #2743: "Unlearn what you have learned." Some of the knowledge you 'know to be true' may not be true, and could be hindering your ability to learn new knowledge.
Again, from the beginning:
You were supposed to learn out how a torque converter achieves torque multiplication, and apply that knowledge to your query.
Torque converter cannot multiply torque at 1:1 drive ratio.
Purpose of a torque converter is torque multiplication
Extrapolate from that....
#2073
Cheap sound system upgrade
So I had my radio out of my Civic earlier today because a CD got stuck in it and I needed to get it out. While I had the radio out, I decided to do a voltage drop test to see how much voltage is lost in the factory wiring. I found that there is actually a significant amount of voltage drop in the constant power wire, and also a bit of voltage drop in the ground wire. With the radio turned up all the way, I was measuring up to about 1.6 volts of drop on the power wire that is hot at all times, and about 0.3 volts of drop on the ground wire. That's almost 2 volts of drop! So what I did is I ran a 14 gauge wire from the ground on the radio to the chassis, and a 14 gauge wire protected by a 10 amp fuse from the under hood fusebox to the "always hot" wire on the radio. So this upgrade cost me nothing since I have wire and a fuse holder sitting here anyway, and it made a decent improvement. What I noticed is that the sound isn't as distorted at higher volumes, which makes sense since the radio is no longer starved for power when it is under load. Anyways, I just thought someone may find this information useful.
#2074
Rep Power: 131 Re: Cheap sound system upgrade
Interesting observation. I've been wanting to do the same with the power window switches to see if the motor struggles a little less. I'm sure you get a little more bass out of the car now.
#2077
Rep Power: 77 Re: How much faster with a 5 speed?
-if you do intend to switch to a banger, keep the sensor that tells the computer what gear the car is in. some cars you need that sensor to tell the auto computer it's in park or neutral in order to have the car start.
#2078
it would feel A LOT faster with a 5 speed. the butt dyno would say it's twice as fast. it's also great because there's one less fluid, two less fluid lines, and less electronics to deal with. i can't find any actual numbers. guessing i'd say you'd drop .5 to .9 off your 0-60
#2079
Es macht nichts
Should be asking 'Which one is less slow?'
You're probably around 17-18ish seconds for a quarter mile with either trans. May as well time it with a calendar.
#2081
Prelude Owner
I think upgrading the stock HU would be more beneficial then the wiring. Yea it would help but you are pushing 10-15W through the wires now (idk what the stock HU speaker output is rated at).
#2084
Received 1,122 Likes
Rep Power: 190 Re: Cheap sound system upgrade
do the head unit. and maybe front speakers. i did both on my car and it made a huge difference, plus i now have hands free, and usb input.
one day ill do the rears when i feel like ripping apart the back of the car
#2085
#2086
I don't think it would make much difference. The aftermarket headunit is probably pushing 22-25watts over a small wire that's less than 10ft long. I doubt you'll hear a difference by upgrading from a 20awg wire to a 14awg over that short of difference and that small of wattage. If you really want to jam out then invest in a 2/4 channel amp(s) to push the speakers harder. .... It wouldn't be a cheap upgrade though.
#2087
#2088
Sudden lack of power
So all of a sudden my car has low power. The engine still runs well and doesn’t misfire and has no relevant codes, but the power is much less than normal, especially at higher RPMs. For example, when I floor it getting onto the highway, depending on speed, it downshifts to either first or second gear like it normally would, but the engine bogs down. It slowly accelerates until the engine reaches around 5000 RPM, but it feels like it can’t keep accelerating until it upshifts. After maxing out the gear it’s in at 5000 RPM, it upshifts to the next gear and begins slowly accelerating again. Fuel pressure is good. Any ideas what could be causing this? Thanks.
#2091
Super Moderator
Received 1,836 Likes
Rep Power: 195 Re: Sudden lack of power
What codes do you have? I know you said none are related but it would be nice to know.
#2097
“Low charge” mode drains AGM batteries?
I noticed that when the alternator goes into “low charge” mode at around 12.4 volts, the battery is actually being drained rather than kept charged. I am presuming that this is because I have a high end AGM battery, which is fully charged at around 13.2 volts instead of around 12.6 like a standard 12v battery. So did the engineers at Honda presume that people would only use OEM batteries, or is this a flaw in the specific type of battery I have? Thanks.
#2099
Re: “Low charge” mode drains AGM batteries?
Well to me it seems stupid for them to design the electrical system to only work correctly with an OEM style battery. IMO, you should be able to use a high end battery without problems. And IMO, the “economy grocery getter” argument doesn’t work because Honda/Acura uses the same “dual mode” charging system on all of their vehicles, including their luxury and sports cars.
