Headlights stay on 2003 civic ex
Old 12-07-2017
CHRISCANI87's Avatar
CHRISCANI87 is an unknown quantity at this point
Ok ... Turn car of.. Turn headlight switch to off and the relay in engine fuse box starts to buzz !!
Causing my headlights to turn on ... Not full power but they will light up and the buzzing continues
i pull relay replace it and it still buzzing i can flick it and it will shut off but not for long
i CAN pull the relay but ill have no headlights for night...
Old 12-08-2017
Re: Headlights stay on 2003 civic ex
While it's acting up, will it light the headlights on both low beam and high beam if you flip the stalk to either?
Both headlights (left and right) come on while acting up?
Do the park lights come on as well, or are they unaffected?
Remove the top column cover, unplug the headlight switch harness connector. Does the problem stop, or does that have no effect?
Old 12-09-2017
CraigW's Avatar
Canadian model ??
The lights on during buzzing may be your DRL lights (High beams at lower power supplied/PWM)
It may be poor solder joints (at relay pins, and connector pins)
That was common on7ths.
Old 12-09-2017
Originally Posted by CraigW
Canadian model ??
Looks like he's in the USA so probably no DRL
Scout1
12-20-2013 10:33 AM
amfcanada
Transmission DIY
02-06-2013 09:53 AM
antproofcase
01-13-2011 03:31 PM
rock88
12-17-2009 09:24 AM
Fabian-
10-15-2009 10:25 AM
Quick Reply: Headlights stay on 2003 civic ex
