replacing the car sterio of honda civic 2010
Rep Power: 0 replacing the car sterio of honda civic 2010
Hey Experts,
My 2010 civic's car stereo (car stereo with USB port under arm rest) stopped working . My mechanic asked to me to replace the stereo . However, I managed to find the stereo of a civic from a junk yard(at a small price) .Looking at it I am not able to figure out, if that is USB compatible. How can i can make sure , if my civic's USB port will work with this new stereo from junk yard.
Should I be looking for anything in particular?
Thanks!
Thanks!
Prelude Owner
Re: replacing the car sterio of honda civic 2010
Is the USB port just for charging or is also for media transfer?
If you take the old radio out you should be able to see where the USB connects to it and compare. If it’s out of a similar year the Port is probably on the back for all models it’s just doesn’t get used if they make a car without USB.
Rep Power: 0 Re: replacing the car sterio of honda civic 2010
Hey, Thanks for the reply.
The USB port is for media transfer as well. I am yet to take out my old radio yet( might take some time).
Anyway I am attaching the pics of the radio I saw at the junkyard. As you can see , there is no slot to connect a USB directly. But I am unsure, if the USB under arm rest can be connected to any of the 4 ports behind this radio by any means .. Thoughts?
Prelude Owner
That smaller connector might be for the USB but I honestly don’t know.
Did you get the radio code for the junk yard radio you pulled out? I think you need the VIN to recover it from Honda?
Did the radio stop working completely, or did only the USB stop working?
The USB could be a wire/harness problem, or a problem in the electronic USB adapter--- on a USA car it is a separate unit from the radio.....about 20 wires on it, bolted to the floor, looks like it would be under the right front seat.
If you replace the radio, it's best to remove your own radio first and record the part numbers from the unit and look for an exact same replacement....or at least has the exact same connectors on the back.
Hey Golnat,
I still have not got the replacement radio yet. There is this guy, who runs the junkyard (he scraps the cars and sells the parts). I was planning to buy from him.So with out the code, we cannot operate the radio? If that is the case, probably I should not buy it..
Hey ezone- The radio stopped working completely. So are u saying there is a USB adapter and that actually does the conversion before the data goes into the alpine radio? If that is the case, radio in the attached pics might work with my USB port under arm rest,because adapter between usb port and the radio might do the trick.. make sense?
I know you are not in the US, and I only have some wire diagrams for North American cars. There were probably 6 different audio system configurations available on that model year, there were differences according to body style and trim level....so be careful and be certain the used radio matches your car.
The radio in your picture--the connectors appear to be in the same configuration (3, 14, 20, 17) as our "premium audio" unit which had the external amplifier. Make sure your old radio connectors are in the same order.
Correct.
USB--> adapter--> radio
My US diagram shows the adapter located under the front seat, and shows it having a 14 pin connector similar to the one on the back of the radio, and a 4 pin connector similar to a usb (actually 5 wires, 4 pins plus a shield)
Your picture of the back of the radio shows 3 large connectors....On our radios the white 14 pin connector is for the USB adapter.
If it's a locking radio, then yes he will need the 5 digit code to unlock it.
If he has enough info he might be able to go through Hondas website to obtain the unlock code....but unless he has the last known registered owners information (that matches Hondas owner database) that may not be possible.
Maaaybe the Honda customer assistance hotline could be a possible way to get it.
