09 Accord locks/windows/mirrors inop - Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 03-10-2017   #1
Derron Kess is an unknown quantity at this point
Well I have a 2009 Honda Accord Sedan and my power locks, power windows and power mirrors do not work. This was after I got my heater core replaced. Not sure what the issue is and neither does the mechanic that did the work. Any suggestions ?
Derron Kess is offline   Reply With Quote
Old 03-10-2017   #2
It's like having amnesia and deja vu all at the same time
Re: 09 Accord locks/windows/mirrors inop
Post moved and retitled....
You know the person who did the work is the one who most likely caused the issue, yes? That person should be responsible for the fix IMO.
Locks/windows/mirror controls all originate at the drivers master switch in the door, so it should be something related to its circuits
From a job like pulling the dash, I'd expect at least one of the harness junction connectors isn't fully seated and locked together (or missed completely), but there are an awful lot of those to choose from. Could be on the fusebox, could be in the kick panel, could be attached to the fuse box, could be one of the connectors that leads to the drivers door.
If the door panel was off, it could be the connector right on the master switch.
Mirrors seems like a simple circuit to start with, check fuses 13 and 16 in the dash fuse box, check all multi-wire connectors in the area, check the harnesses that leads toward the door hinges and disappears.
ezone is online now   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright 2017 CivicForums.com We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
