2015 Honda Civic GPS IMOBILIZER REMOVED
Rep Power: 0 2015 Honda Civic GPS IMOBILIZER REMOVED
Now the car won't start, i spliced everything back to where it belongs but no go....... Its almost as if the ignition doesn't read the key, it dings with key in ignition and door open but if u turn to start nothing happens, the radio don't come on and you can't move gear shift unless u use that unlock tab next to it. Help
Re: 2015 Honda Civic GPS IMOBILIZER REMOVED
That is not immobilizer related........And why the HELL would you do ANYTHING like this to a NEW car.
Any sparking or shorting of wires occur during this operation??
See if your brake lights and horn work, inspect the large ampere fuses in under-hood box.
Did this have a pushbutton start, or a regular key?
If you can't put everything back exactly the way it was and get it to work correctly.......
Tow it to a good dealership and get your credit card(s) all warmed up.
Write down everything you did so the tech gets a straight story about what they are gonna have to figure out, and leave the notes laying on the seat so the tech can find it.
Kkoestner
11-22-2015 04:50 PM
Youngrob650
11-12-2015 11:01 PM
MadFlavorJ
10-20-2015 02:30 PM
