headlight/signal/high beam switch on column
Rep Power: 0 headlight/signal/high beam switch on column
I have a 2000 Honda Civic DX. I was adding an aftermarket auto headlight device. I unplugged the wiring harness that plugs into the switch on the column to test and find the closures for the driving, head, and high beam lights. Upon testing the various closures, all I could find was the driving/dash light closure. If anyone has a wiring diagram for this plug, I would appreciate if you could share it.
Anyway, I plugged it back in and now the turn signals do not work. The turn signal indicator lights on the dash or not working either. The emergency flashers are working correctly, so the relay in the under dash fuse box appears to not be the problem. I changed out the blown 7.5 MA fuse and they are now working.
I am now afraid to find the closures by trial and error for fear of blowing another fuse. I also noticed the first time I unplugged this from the column switch that one of the wire contacts in the wire side plug has melted out the plastic around it to where it does not make contact very well anymore.
Re: headlight/signal/high beam switch on column
If it has melted the wire terminal out of the plastic holder like that, it needs the plug and wire pigtail replaced, and also should get a new headlight switch.
The headlight wire and/or switch recall on some 7th gen Civics is for a problem just like what happened to yours.
I can't link a wire diagram for you, sorry.
bhollie
11-11-2015 05:31 PM
dtdoyle
25
08-30-2015 06:57 PM
Mucklow
08-22-2015 06:28 PM
qlitten
07-21-2015 03:12 PM
