Radio trouble!!!
Old Apr 24, 2012
jimlydon's Avatar
jimlydon is an unknown quantity at this point
Radio trouble!!!
So, I have a 2005 Honda Civic, the basic one with manual windows, locks, etc. I recently tried to install a new radio. I was holding the new unit in my hand, and i plugged it in, and it was working fine. Then i tried to slide it into the dashboard. It stopped working completely. Now, when i start the car, the gas, temp. gauges and the speedometer freak out, almost like the battery is dead, only it isn't, and the car starts fine. Also, when i open the door with the keys in the ignition, it doesn't beep like its supposed to. And, the dome light doesn't come on when the door opens (but when you switch it to the "on" position, it works, so it has power). I checked as many fuses as i could think of. I even tried putting the old radio back it, but got nothing. Any ideas...anyone??? How did i mess it up so bad????
Old Apr 24, 2012
Re: Radio trouble!!!
You blew fuses I'd bet.
Check both fuseboxes.
Old Apr 24, 2012
jimlydon's Avatar
I checked both fuse boxes...
Old Apr 24, 2012
Fuse 8 in the dash fusebox
#8 also supplies power to the MICU, which runs the dome lights,
and fuse 9 in the engine compartment box.
This also powers parts of the gauges and immobilizer.
HTH
Old Apr 24, 2012
Check fuses with a test light. Not by pulling them out.
Or replace with known good ones.
HTH
Old Apr 24, 2012
jimlydon's Avatar
THANK YOU SO MUCH! Fuse 9 in the engine compartment was blown. I was an idiot, and thought that when the manual said "Back Up" it meant it was a spare, so I didn't bother to check it. Everything's working perfectly!
ricer_em2
May 11, 2016 08:09 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Nalmonte
Sep 28, 2015 01:10 PM
Bruce2
Sep 27, 2015 08:45 PM
Mc7602
Sep 17, 2015 02:01 PM
