oil pressure guage - Honda Civic Forum
oil pressure guage
Old 07-30-2008
chopper202 is an unknown quantity at this point
oil pressure guage
Hey I just bout a cluster of three guages, an ammater,oil pressure and water temp I dont have any trouble putting the ammater in but the oil pressure and water temp I am having a bit
ok first question can I take oil pressure if I install a T junction before my oil cooler??? if not there I have to tap into the block yea???
and the water temp the same deal drilling and tapping a hole??? thanks for any help on this as im soooo close to paying for it to get done
chopper202 is offline
Old 07-30-2008
Re: oil pressure guage
its alot of work, check the diy threads in the tech forums
gearbox is offline
Old 07-30-2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
i don't know why you couldn't just do like everyone else and T off the block where the O/P sending unit goes in. just remove it and get a proper T fitting. like GB said though, check the DIY threads for the right sizes and such. hell, there may even be part numbers in there somewhere....
tuningmycivic is offline
Old 07-30-2008
ok this sandwhich plate seems like a fair easy option from what ive searched???
http://cgi.ebay.com.au/Universal-oil...QQcmdZViewItem
appears to save alot of hassle???? either that or buy an electronic one lol
Old 07-30-2008
The Video Collector
trev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to beholdtrev0006 is a splendid one to behold
sounds like a ton of work
trev0006 is offline
Old 07-31-2008
we will have to see ill try and machine one of those addaptors with a few mods to make it fit nice and snug... i put a pressure guage in on my 13b turbo rx4, an autometer one but that was a walk in the park compared to this...being a dry sump you can tap into it anywhere lol... looks like i got a big weekend ahead...
Old 08-06-2008
Jap-Euro Fusion
Boilermaker1's Avatar
you can T it into the line anywhere. At the oil cooler is fine, I had it there once, measured no difference between the cooler inlet and the block outlet.
Boilermaker1 is offline
Old 08-10-2008
i just bought one of those adaptor plates, it works a treat and no tapping into different lines... ill post up some pictures
Old 08-17-2008
ok just a question what is normal oil pressure at about 3,500rpm??? because mine is reading around 80psi at 3,500 i was just wondering if it was normal???
cukaracha
6th Generation Civic
30
07-26-2015 01:01 PM
looktotheson
40
07-10-2015 08:08 PM
silentz
1st - 5th Generation Civic
07-09-2015 09:16 PM
Mike_47
07-08-2015 03:42 PM
AaronSorenson
07-07-2015 10:40 PM
Quick Reply: oil pressure guage
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
