Pleasr HELPPPP having issues with aftermarket projectors PLEASEE HELPP
Old 01-10-2008
hondasport2001's Avatar
hondasport2001 is an unknown quantity at this point
Exclamation Pleasr HELPPPP having issues with aftermarket projectors PLEASEE HELPP
I have an 01 civic with aftermarket headlights. The problem is all my lights all work except my low beams. I've checked the power, the relay, fuses, the bulbs and even switched the connector from the high to low beams and they work. so its not the bulbs and i also get power to the end of the wire so i knwo that there is some kind of power making it to the headlight not sure if its enough tho anyone have any ideas please let me knwo i need to fix this asap i need to goet my inspection done you can even call me at 516-807-4678
if you knwo what this is thanks Sal..
Old 01-13-2008
Re: Pleasr HELPPPP having issues with aftermarket prokectors PLEASEE HELPP
does any one have an idea on what this is ???
Old 01-13-2008
TRIZ's Avatar
Re: Pleasr HELPPPP having issues with aftermarket projectors PLEASEE HELPP
So you are sure the bulbs are good, and theres power to the wire so its not the switch.... I'm guessing ground. Try testing different power and ground wire combos and I think you'll find your problem. If the ground wire isnt connected, the circuit wont be complete and that would hinder it from illuminating your bulbs.
A good idea would be to hook a multimeter up to the ends of the connectors and test the voltage. Most multimeters can also test if the circuit is complete/ properly grounded.
Old 01-13-2008
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
noticed the 516 number. I am out on Long Island too. There is also a meet out west just after where the northern state and 110 meet. You are welcome to come by. As far as your lights go. We can meet up and I can take a look at it. Is it a regular halogen setup or HID?
Old 01-13-2008
its a regular setup with aftermarket projectors no hid's i did put brand new bulbs in it... so i decided to check power comming out rite to the bulb adn theres not 12volts im getting .01 so i head it might be the headlight switch ...do you guys agree ? and where and when is this meet ...
Old 01-13-2008
TRIZ's Avatar
Do you have your multimeter on the correct setting- what does your other light register at? Trace the wires back.
Old 01-14-2008
ryox82's Avatar
From the expressway go to 110 (exit 49) and go north. Right after the northern state you make a left at the light (it is a funky turn). Make the first right and on the left hand side there is a building that says "Social Security". We meet up on the lower level of the parking garage. About this headlights....do the bulbs light dim? Did you switch bulbs before or after you had this problem?
Old 01-14-2008
electric130's Avatar
you do know that your car is a ground switched H4, right? that means you need to splice the single power wire to go to both head lights, and then each low and high have respective grounds. can you verify it's powered right? on the H4 plug, you should have 1 power and 2 grounds, not 2 powers and 1 ground.
Old 01-27-2008
ryox82's Avatar
any updates? did this get fixed?
TiggerDX
06-18-2015 01:43 PM
carid
06-05-2015 11:51 PM
Youshoe
05-22-2015 09:36 PM
CivicHX01
11-29-2001 03:48 PM
klam
11-16-2001 03:36 PM
Quick Reply: Pleasr HELPPPP having issues with aftermarket projectors PLEASEE HELPP
