before...
after...
and since there is no diy that i found im gonna make one below.....
Supplies
2-3 can of wheel paint or whatever paint you want.
1 can of primer or adhesion promoter
painters tape
paper
playing cards
1. you want to clean your wheels
prep work is important. i washed my car like two days before so when i had to clean the rims it didnt take long. just a quick wipe down BUT you really need to clean the rims alot.
2. next take the paper and mask off the tires. use the cards to make ring around the rims check the picture to see what im talking about. this can be done second or third but i think its best to do it second even though i did it 3rd.
3. spray your primer or adhesion promoter. i used the adhesion promoter because i didnt want to sand or use steel wool. but you can or should if you use primer. also if you have any scuffs take the time to clean that up and smooth it out. also let it dry after you spray primer or the promoter.
4. spray a base coat let the paint dry and you dont have to lay the paint on too thick.
this pic is for steps 2-4
5. after the paint dries, spray the rims again appling another coat of paint. let paint dry. repeat this step alteast 3 times. i did about 4-5 coats
6. Enjoy your wheels
For a more extensive write up check out vwvortex. Go vdubs.
http://forums.vwvortex.com/zerothread?id=3156862
oh remeber to cover your tire cap and take out your center caps if you dont want them painted.
