Re: 14" alloys - questions
I've never bought from that place before. Not sure if it's reputable. If you search the web for the name of the business, you might find some results. You can also check the better business bureau. The stock wheels will swap out just fine. It says on the site it's "Matched to your civic" which im sure just means that it fits the car already. I'll be honest with you, from my perspective, it seems expensive. Did you try searching other forums for stockers? Or ebay? I donno, 130 a wheel sounds like a lot for a 14 inch. But It's an OEM part, so it's going to naturally be expensive.
