Re: Not your ordinary camber question
This is why I say do it right or dont do it at all. I got a camber kit with my setup from day 1...unfortunately I cheaped out on the alignment like a dumbass and ended up with this
1 front wheel had 0 camber
1 front wheel had -2.0
both rears had ~-2.5
i paid 65 for that alignment, and it was a good thing that I take my wheels off to wash them, and the underside of the car that I caught the camber wear within 3000 miles. Just got another alignment done that cost me 125, so thats a total of 190 because I didnt fess up the 125 the first time, money down the drain.
get a camber kit ASAP and get it aligned so they actually adjust the camber settings manually...if you live anywhere near Philadelphia by any chance I can send you to the place that did my second alignment they will take good care of you. Its not safe driving the way you are because if the tires wear enough on the inside, and get to the cords, its a major safety issue as far as blowouts...god forbid you blow a tire, then you run the risk of having to get a new rim...or if it happens on the highway, possibly a new car, worst scenario, you wont be around to get the new car. Never cheap out on stuff like this, but since you did, I would try to avoid driving the car as much as possible. GL
