Hatch back lock broken
Rep Power: 0 Hatch back lock broken
So I bought this car recently about a month ago and the hatch back doesn't open it's either locked and won't unlock. Or something I'm hoping to get some help with this. I pull the handle and nothing happens so that's detached from the levers in side the door and neither of my keys will go I. The lock cylinder let alone unlock it.
There is no pop truck lever or button.
This is as far as I can get the key in the cylinder
Side veiw
Side veiw
Re: Hatch back lock broken
Squirt penetrating oil into that lock cylinder and give it a little time to soak in
Remove trims from door sill and levers, see if you can work the cable manually?
Fold down rear seat, access the latch or linkage from inside (may require removing trims or entire panels from the tailgate, IDK what is there to work with)
Rep Power: 0 Re: Hatch back lock broken
I squirt penetrating oil in there it honestly feels like someone tried to smash the pins to break into it and I can't even get the hatch open at all to remove any of the plastics from inside and I'm not sure what triks your talking about on the outside .the plastic with the Honda symbol on it?
If you pull apart your drivers side sill plate and get access to the cable that goes to the trunk you might be able to manually push the cable to pop open the hatch.
Can always get a dremel and cut the interior plastic to make a access to back side of the latch..
Swing by a junkyard to get replacement piece of trim if your concerned, else stuff a stuffed panda or something in the hole..
Kevin_646
06-20-2018 11:02 PM
firstcarforme
06-20-2014 08:27 PM
haydeon
02-25-2014 09:09 PM
Jdoe
07-01-2012 02:10 PM
