94 Civic CX cant figure out my problems
Rep Power: 0 94 Civic CX cant figure out my problems
Alright so i have a 1994 Honda Civic CX with the d15b8, 5 speed manual, brand new xtd stage 1 clutch, resurfaced flywheel, less than 50 miles on clutch and resurfaced flywheel.
Alright so heres my issue
1. idles fine when cold warms up idle bogs up and down.
2.sputters once and a while on take off.
3.(my big issue) alright so i can start driving going through my gears fine once in a while if i hit 3rd below 35 it will sputter and buck (once in a while), bit if in in 5th gear when accelerating at anything below 80mph its sputters and bucks so hard it feels like my cars going fall apart, down shift its fine, cant even hold 50mph or even 60mph in 5th gear can hold 70mph just cant give it any gas.
I use to be able to cruise through town at 35 in 5th gear but not any more, i cant figure out my problem Its been doing this since before i replace my clutch i had to make a 1000 mile move with my car doing this, im so scared something bad is going happen next time i drive it so i dont i walk everywhere right now, can someone please help me figure this out?
1994 Civic CX new xtd stage 1 clutch and resurfaced flywheel. Less than 50 miles
my problems
1. Cold idles fine Warm idle bogs up and down
2. Occasional sputter at take off
3.(main problem please help!!!) I take off start shifting normally hit 3rd once in a while will sputter and buck (once in a while) but my main issue is 5th gear i cant hold speed at anywhere from 35-70mph let alone accelerate without it bucking and sputtering really bad like its going fall apart, I cant accelerate in that gear at all unless im going 80mph but can hold speed at 70mph, does it everytime too, sometimes it will do it in all gears so i have to down shift till it stops its been doing it since before i replaced the clutch i had to make a 1000 mile move with this happening.
can someone please help me with this issue.
my problems
Re: 94 Civic CX cant figure out my problems
CEL light on or codes?
Check for vacuum leaks
Power balance (drop) test the cylinders
Possible ignition coil or igniter issue
Compression test
Compression test
Rep Power: 0 Re: 94 Civic CX cant figure out my problems
My CEL does work but does not come on during any of the issues and after starting the car goes right off, never pops back up, i have zero rod knocks, downshifting instantly fixes the issue so i run around in 4th if i do drive it which i dont right now
That one is old enough it cannot detect nor display codes for misfire.
Do you know what a single dead cylinder misfire feels like? Can you detect it yourself while driving along?
None of my cylinders are dead i pulled each plug wire and got the same reaction out of each cylinder just a sudden bog, i had a misfire back in may before all of this occurred changed my spark plugs and all was better. I ran my ECU today, no codes at all, reset my ECU and still doing the same thing, It idles fine till it reaches operating temp, then if i give it a little gas i mean not even a 1/10th of the pedal it bogs up and down a couple time now and stops. I disconnected my O2 sensor to see if thats the problem, it runs the exact same, do you think my o2 sensor is bad?
Also I have ran it completely out of gas before and a couple times to almost out, could it be a failing fuel pump?
I dont have a full exhaust on it anymore it probably comes out 1ft and half past the resonator, could it be insufficient back pressure?
I dont have the ability to make a video plus the main problem isnt till i hit the hwy which road conditions were im at are very hazardous at the moment where im at but as soon as i can i will
Hell, I'm not even one of the cool kids but I still got a smartphone (only 2 short years ago LOL)
Which brand and style (ex: iridium, plattinum) spark plugs are you using?
Did you check the spark lug gap prior to installation?
Perform a smoke test for vacuum leaks yet?
xkractedx
01-28-2018 08:07 PM
Elarsen8291
11-02-2013 02:02 AM
civic09ex8
03-19-2012 09:19 PM
