92 EG hatch broke down...fuel pump? which one.
Rep Power: 0 92 EG hatch broke down...fuel pump? which one.
my 92 hatch with a del sol d16z6 broke down going into second on my way home from work at 10:40pm...worst time possible,
been doing some research and it said main relay or fuel pump needs replaced...
the guy i bought the car from never replaced the fuel pump but it does has a d16z6 in it, so i was wondering do i just replace it with a stock fuel pump or do i need one to support the d16? seen some on ebay for $29 but it says 93-97 del sol...not 1992. ?
any ideas guys?
any ideas guys?
Rep Power: 0 Re: 92 EG hatch broke down...fuel pump? which one.
im gonna start by replacing the main relay....but do i get one for 1992 civic 1.5l? or the 1.6l thats in there, i dont want to be running lowers fuel made for a 1.5l that came in the car opposed to having a 1.6l in there now
my 92 hatch
First you should figure out if it has lost compression, spark,or fuel....then figure out why
so check the spark plugs and dizzy first should i worry about the alternator? it is cranking but no turnover, then il just replace the main relay see if thats the issue to rule that out
