Crunching/Creaking Noise When Turning
Rep Power: 0 Crunching/Creaking Noise When Turning
I've noticed a crunching/creaking noise coming from the front left wheel when i make a tight turn, say 90 degrees. I've looked around and think it MAY be the ball joint or tie rod causing it.
If that is the case, how big (expensive) of a job would this usually be for a mechanic or would it be something that is relatively easy to fix myself?
Additionally if you don't think it's either of these I'd appreciate the feedback.
