1995 Honda Civic EX Coupe D16Z6 Manual Transmission Build EJ11
This is my third build thread on this forum. My first was a 1988 CRX HF, not done.
https://www.civicforums.com/forums/1...5z7-build.html
My second was a restoration of a 2005 Civic EX Special Edition, complete for now.
https://www.civicforums.com/forums/1...ion-d17a2.html
And this one is for my 1995 Civic EX Coupe 5 speed manual transmission or EJ11.
I will be:
1. Replacing the rear main seal, flywheel, pressure plate, clutch friction disc, throughout bearing, and pilot bearing
2. Installing a Transmission from an EK-3 Civic Ferio VT-i D15Z7
3. Installing Innovative Mounts 60A & stock front lower mounts
http://www.evasivemotorsports.com/mm...OVATIVE_BILLET
4. Rodatech/Motor Mount, Lower Left
http://www.autozone.com/external-eng...70683_0_18277/
5. Rodatech/Motor Mount, Lower Right
http://www.autozone.com/external-eng...770690_0_4222/
6. Skunk2 Pro-C Coilovers
http://store.skunk2.com/suspension-t...coilovers.html
7. Plasti Dip (spray my Skunk2 struts in order to not advertise to thieves)
https://www.dipyourcar.com/PlastiDip-Spray-All.html
8. Acura Integra LS Mesh Rims with Walmart Tires
http://www.walmart.com/ip/Tiger-Paw-...55R15/43081618
9. Gorilla Automotive VS401C Outer Mount Valve Stems
10. True Metallic™ Wheel Kits, Aluminum W/2 cans of gloss
https://www.dipyourcar.com/True-Metallic-Wheel-Kit.html
11. Power Steering Rack http://www.ebay.com/itm/150903884776?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
12. Valucraft/Tie Rod Ends
http://www.autozone.com/suspension-s...67_10302_3152/
http://www.autozone.com/suspension-s...68_10302_1905/
13. Clear Corner Lights http://www.ebay.com/itm/191515556215?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
14. Stainless Steel Brake Lines http://www.ebay.com/itm/201415251250?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
15. Rear Camber Adjustment Arm http://www.ebay.com/itm/161756926274?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
16. Energy Suspension 16.18103G Hyper-Flex System Black Polyurethane Bushings http://www.ebay.com/itm/161319407637?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
17. Rear Disc Brake Conversion from an Integra
18. 1992-1995 Honda Civic Parking Brake Cable - Rear Right - Beck Arnley 094-1014
http://www.partsgeek.com/ss/?i=1&ssq...4-1014&x=0&y=0
19. 1992-1995 Honda Civic Parking Brake Cable - Rear Left - Beck Arnley 094-1013
http://www.partsgeek.com/ss/?i=1&ssq=094-1013&x=0&y=0
20. Kensun HID Xenon Conversion Kit "All Bulb Sizes and Colors" with Premium Ballasts - H4 (HB2) (9003) Bi-Xenon - 5000k
21. Lower Ball Joints
http://www.autozone.com/suspension-s...er/181121_0_0/
More to come
I will be:
Amazon.com: Kensun HID Xenon Conversion Kit "All Bulb Sizes and Colors" with Premium Ballasts - H4 (HB2) (9003) Bi-Xenon - 5000k - 2 Year Warranty: Automotive
More to come
Re: 1995 Honda Civic EX Coupe D16Z6 Manual Transmission Build EJ11
This is the reason for not posting anything on this build.
I decided to go a different route and I will be buying a Go Pro 4 Silver Edition for documenting the build. Hope to see you all there.
Happy New Year.
Happy New Year.
Trainingdragon
Suspension DIY
10-23-2015 07:12 PM
