EJ1 D16Z6 RPM guage problem
Rep Power: 0 EJ1 D16Z6 RPM guage problem
Hi dudes, i'm from brazil and i have a 94 civic ej1 exs mt d16z6.
My car are have a rpm guage problem, at idle the guage shows 700-800rpm, at 60mph show 2000rpm and the cut-off are on 5900-6000 when its suppose to be 7200 rpm
what can be the problem?
ps: sorry my poor english
Re: EJ1 D16Z6 RPM guage problem
Is that the original and correct engine for that year and model of car?
Is the computer correct for the engine you have?
Did someone replace the engine but not replace the computer with one specifically for the new engine?
Rep Power: 0 Re: EJ1 D16Z6 RPM guage problem
The car are the same as brand new, same engine, same ECU nothing has been changed.
If the tachometer has become inaccurate, readings may appear lower than actual?
I bought the car from a friend of mine and he told me that some time ago the rpm began to show a lower value than the actual.
If you want to confirm the tachometer on the dash is not accurate, obtain a different "known good" tachometer (digital, aftermarket gauge, or voltmeter-multimeter with tach function), connect it to the RPM test connector then compare?
They engine are running 7200rpm but the tacho shows only 6000. whey i'm driving the rpm increase normal at idle to 2000 rpm after this increases slowly
The tach gauge in the dash is probably bad, but using another as a test would confirm the inaccuracy.
i dont have money to try other guage. Any other optiom?
-buy a new gauge
-buy a good used gauge from a auto recycle yard
or ignore the bad gauge, it is not hurting performance nor hurting the rest of the car
Wild Cranker
05-19-2015 06:10 PM
tylerginevan
04-27-2015 12:29 PM
McD
04-16-2015 10:46 AM
dooner24
04-14-2015 07:51 PM
Aznnp77
11-08-2001 04:49 PM
